Question for you northeners!!!
Old Dec 4, 2002 | 04:08 PM
jwrape's Avatar
It is just starting to get cold down here in Georgia. What mixture of antifreeze to you guys run. How much antifreeze and how much water? I figure you northeners are pro's at this keeping warm stuff.
jwrape
Old Dec 4, 2002 | 04:12 PM
DC Larson's Avatar
I use half and half. Thats whats recommended for up to 40 below....which it has got around here before.
Old Dec 4, 2002 | 04:14 PM
jwrape's Avatar
That's what I have always used, just checking.
Old Dec 4, 2002 | 04:20 PM
Glaffer's Avatar
50 - 50
and have never had a problem...
Old Dec 4, 2002 | 06:02 PM
Thad's Avatar
I use 50/50 also. They say if you go much stronger it will turn to a gel and plug up your rad. It was minus 30 the other night and the truck started fine with remote start.
Old Dec 4, 2002 | 06:31 PM
J-150's Avatar
50/50 in Canada
Old Dec 4, 2002 | 08:33 PM
01 XLT Sport's Avatar
New Hampshire here and I use 50/50 as well. I think about the only problem people have in the winter as far as with their car/truck is getting it warm in the mornings. If its real cold out, though I have never done it, don't need to truck heat works great, but some people will particially block off the front of the radiator so the engine will run warmer (closer to normal operating temp). I know on most the school buses they have a thing over the front of the bus in front of the radiator and it zips up and I see them running around in winter with them almost completely zipped up.
Old Dec 4, 2002 | 10:16 PM
f-150_91's Avatar
Same here as everyone else. I use 50% Amsoil's Antifreeze and 50% water. Seems to work fine.
91
Old Dec 4, 2002 | 10:18 PM
Harley#356's Avatar
whatever came in my truck from the dealership anotherwords...i have no clue whats in there
Old Dec 4, 2002 | 10:24 PM
TZRLightning01's Avatar
50/50 Zerex and water
Old Dec 5, 2002 | 09:42 AM
Green_98's Avatar
isnt your 50/50 mix supposed to be with distilled water?
Old Dec 5, 2002 | 12:30 PM
Green_98
"isnt your 50/50 mix supposed to be with distilled water?"
Not sure if it matters for the raditor or not, would not hurt and actually be better.
As far as distilled water, on batterys that are not sealed where you can pull the caps off you "should" always used distilled water to fill them up when needed. Water that is not distilled has junk in it, sometimes litttle metal particals that will degrade the cells in the battery.
