303 areospace
Old May 22, 2002 | 12:42 PM
mudd1's Avatar
303 areospace
will 303 fade my dash or is it superior to all others? is it also good for applying on the outside plastic trim?
Old May 22, 2002 | 03:31 PM
Golfer71's Avatar
303 will NOT fade your dash. It will prevent it from doing just that. It gives your plastic parts 100% UV protection as well as repels dust and dirt. I live up in teh mountains at a high altitude and I use it on my Spa Cover which is out all day everyday. It hasn't faded one bit in 3 years. I use it on my bed caps, bumber cover, door adn window seals and on my tires every couple of months in between uses of Meguiars Endurance.
Old May 22, 2002 | 04:24 PM
Intel486's Avatar
I'm not going to say 303 gives 100% UV protection but it does have UV protectant in it. Most people with boats use it on their boats which are always out in the sun. If it works for them, then it'll probably protect your dash.
Old May 23, 2002 | 08:48 AM
Y2kXLTSport's Avatar
Where are you guys finding this stuff. I've looked at the local autoparts places and no luck.
Old May 23, 2002 | 09:00 AM
LINYScrew's Avatar
I have only been able to find it at marine supply
places. It seems boaters have been using it for some time. I saw some one mention that True Value
hardware stores is supposed to start carrying it but as of have not found it there. I have only used it once but liked the results.
Old May 23, 2002 | 11:36 AM
kriggins's Avatar
I found it at http://www.properautocare.com.
Kevin
Old May 23, 2002 | 01:05 PM
Intel486's Avatar
I get mine at West Marine. If you don't have one, then try some boating supply stores.
Old May 23, 2002 | 08:57 PM
cnote's Avatar
Summit Racing
Try Summit Racing. I seen some 303 Protectant Kits in their May - June catalogue. I don't know if it is the same stuff.
Old May 24, 2002 | 09:05 AM
Ranman's Avatar
You can actually but 303 Protectant from the Spa Depot www.spadepot.com. I get it here for my hot tub. Shipping is free too.
Old May 28, 2002 | 02:09 AM
n6van's Avatar
You should be able to find 303 at most RV supply houses. That is where I get it here in So Cal. I have a Colgan Bra and they also recommend it for keeping the bra looking good. Great product!
