Someone had put like a tag or something above my f150 and i need to know what i can use to take the goop off and not mess up the paint its like a Styrofoam
Let's start with the least aggressive method first. Take a hair dryer and heat the area up. Then take your finger tip and see if you can start rolling up the foam and adhesive from one end. The heat softens up the adhesive.
If that doesn't work, a product called Goof Off, which you can buy at Home Depot or other similar stores would probably take it off too. BUT - I'd test it on the paint in a "hidden" area first, to make sure it doesn't attack the paint.
