would be lost without it
Old Feb 22, 2014 | 12:08 PM
gbctrdrman's Avatar
I use this stuff on everything, boat, motorcycle .. really makes wiping down the car or anything a lot easier... it applies a thin coat of wax and makes it easier to maintain... I have been using it for years... it really helps if you don't want to wipe it down after a quick wash, helps the water bead off.. just wanted to pass it along
Old Feb 22, 2014 | 12:19 PM
Thanks! Where do you get it?
Old Feb 22, 2014 | 01:18 PM
sam1947's Avatar
Here is one place, Jim
Eagle One 2089618 Wax As-U-Dry - 18 oz. : Amazon.com : Automotive Eagle One 2089618 Wax As-U-Dry - 18 oz. : Amazon.com : Automotive
Old Feb 22, 2014 | 01:22 PM
gbctrdrman's Avatar
I get mine at Orielly auto parts .. It's pretty cheap..
Old Feb 23, 2014 | 10:14 PM
theo45's Avatar
Have you tried it on plastic exteriors? Looks similar to Turtle Wax ICE Spray Wax.
Old Feb 27, 2014 | 02:49 PM
Phillip S's Avatar
Good Stuff! Pretty effective product with the ability to quickly wax your truck while its still wet. I use Wax AS-U-Dry regularly after every wash and between my Klasse Sealant.
Old Mar 11, 2014 | 08:48 PM
lowrider111's Avatar
Tried this product many times. Yes it works well, but protection is not that tough. It could be a good alternative for a quick detailer spray.
Old Mar 12, 2014 | 11:06 AM
tg150's Avatar
I use to use E1 for years on my truck and wife's suv when drying, worked pretty well... PepBoys always had it on the shelves.
I've since switched over to a Wash n Wax car shampoo though.
Old Mar 12, 2014 | 09:39 PM
May I ask what wash and wax shampoo are you using? Is it easy to dry it off?
Old Mar 13, 2014 | 09:40 AM
tg150's Avatar
Sure..Currently im useing Chemical Guys Wash and Wax Shampoo w/Gloss. You just need to dry it off like a regular wash, very easy.. Not that expensive either and I get great results, you only need 1oz for a 4-5 gallon bucket. You can buy it at Autogeek or directly from CG's which is much cheaper. For instance.. 16oz is on sale for $4.99, a gallon with cost you $15.99
Here's a link.
http://www.chemicalguys.com/Chemical...cws_102_16.htm
There's also other brands you may find locally like.. Griots Wash and Wax, Meg's Ultimate Wash and Wax, Mothers Wash and Wax etc..
Old Mar 13, 2014 | 08:29 PM
Here's a link.
Thanks man for the link... I will check it out!
