Wheel Care
Does anyone know a good way to clean wheels? Every time I clean my wheels, it takes about 1-2 days and they are covered in brake dust. Does anyone know a cleaner that will not attract brake dust? What about those dust shields that fit inside the wheel? Anyone use these?
Bigworm
'97 XLT Expedition 4X4
4.6L V8, BFG 265/75R16 A/Ts & Lots of dreams
Bigworm's WebSite
Bigworm's Photos
Bigworm
Bigworm's WebSite
Bigworm's Photos
Have not seen a product for wheels that claims that it doesn't attract brake dust. To minimize the work to clean them, I wax my wheels. The dust comes off much easier and eliminates the need to use a harsh chemical cleaner.
I have not used the dust sheilds but have heard they work. You can usually see them from the outside like you see your caliper and rotor now so it may be an appearance issue for some people.
Another alternative is dustless brake pads. I believe Raybestos makes them although I do not know if they make them for a truck application. They came stock on my '99 Taurus and, much to my surprise, the brake dust is reduced dramatically.
Hope this helps.
'99 L, JL Stage II Ram Air, Bassani cat-pipes, Borla cat-back, R9 Superchip, Cal-Tracs, Chassis Tech 2" drop shackles, Water Wetter
'93 Cobra, 1 5/8" FMS shorty headers, 2 1/2" Mac cat-pipes, Borla cat-back, 180 degree thermostat, 4" ram air, 3.55 gears, March pulleys, strut tower brace, Kenne Bell flip chip, Crane Hi-6 ignition, Crane coil, Global West Trac-Link, Hurst chrome shifter, Canton oil pan, BFG g-force kd tires
Hope this helps.
BlueOvalBolt, Thanks a million for your response. Do you have a suggested wax? Also, one list member told me that he heard that the dust shields possibly trap heat and may cause the rotors to warp. Ever heard this? Thanks again!!
Bigworm
Bigworm's WebSite
Bigworm's Photos
Bigworm
Bigworm's WebSite
Bigworm's Photos
No specific recommendations for what wax to use for the wheels. I don't use my "good" stuff for the wheels, generally some old wax that I have stopped using for whatever reason.
I would suppose that it would be *possible* for heat to build up and cause damage to the rotor. IMO this would be unlikely unless you are autocrossing or very hard on your brakes to begin with. They don't enclose the rotor and, the ones I have seen, have vents in the sheild to direct air into the rotor area. Not an expert, just my opinion.
I don't know if this will help you or not...
I noticed that my wheels on previous vehicles would not build up grime as fast, if I sprayed the tires with ArmorAll or whatever I had. Then after spraying the tires, I would just use a clean rag to wipe the excess off the wheels before wiping the tires. They collect a little dirt dust, but the brake dust didn't seem to stick and buildup as quickly. I say previous vehicles 'cause I just haven't cleaned my tires that well yet on this one.
'97 F-150 Lariat SuperCab 4X4
- White/Silver, 4.6L, Auto.
- Tinted Windows/Bedmat/Toolbox/Lund Bug Deflector/Ventvisors/Extra Horns
- 265/75/16 BFGoodrich on polished 16x8 AR-136's
- Cat-back Dual Exhaust (Straight pipes with big chrome tips)
- Polar Bear Grille Guard
- Cranked Torsion Bars for 1" Lift
BigWorm
I do not know what will keep the dust off. I allways wax my rims, helps to keep it from distroying the clearcoat.
One thing I will recomend for cleaning them is EagleOne AtoZ it is the best stuff to clean them, escpecially if you have billet wheels like me.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bullet Cat Back, Superchip, K&N FIPK Intake.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Alpine CDA-7845, ADS P640 Amp, Focal Poly Kevlar seperates.
http://members.tripod.com/donf150/Welcome/id7.html
[This message has been edited by Don C (edited 11-28-2000).]
Thanks for your help, guys!!!
Bigworm
Bigworm's WebSite
Bigworm's Photos
Bigworm
Bigworm's WebSite
Bigworm's Photos
PLEASE!!!
Bigworm
Bigworm's WebSite
Bigworm's Photos
Bigworm
Bigworm's WebSite
Bigworm's Photos
I believe i have the solution. At Wal*Mart there is a cleaning set for wheels.
i forgot who made it but the cleaner SUCKS.
there is another bottle though that you spray all over your wheel and it keeps break dust from forming quickly.although you will get brake dust even after using this it will wipe off with a dry rag.it keeps the dust from attaching to the wheels.
also if you have trouble ever getting it off
"PURE AMMONIA" will work better than anything. it will run right off.
Sorry to harp on this again,but Mothers Clearcoat Wheel Polish leaves a really slick finish on mine. The Eagle One A2Z
cleaner is the best I've ever used!
Even cleaned the Calipers,I never knew they were supposed to be silver=),,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Euro tails(Altezza style)
Cobra 75WXST cb w/weather alert
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good]
Viper 500HF Security system
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order www.my-f150.com Still want to lift it,YESSS!
FENDER GUITARS,ROCK!!!
http://www.bigsandy.net
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
[This message has been edited by 98SCREAMER (edited 12-09-2000).]
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
