Put a shine on tires and trim
I have some friends that tell me it seems to be more trouble than just using armor all. But the big advantage is that the mop n glow doesn't wash off with the first bit of water that hits it.
00' 4.2 5sp
3.55
K&N air filter
Flowmaster 40 series
single in dual out
00' 4.2 5sp
3.55
K&N air filter
single in dual out
Trouble??? In what way, application, negative long term effects?
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications: K&N FIPK, Stepshield door sill protectors, Performance Accesories 3" body lift, Lift Lips, Gabriel Gas Ryder LT VST Shocks and Daystar front anti-sway bar polyurethane bushings.
Photos at: http://www.communicomgroup.com/jmtruck
Application on tires can be a little troublesome. it takes seeral coats the first, and they need to be evenly spread as possible. As far as long term effects, none negative here yet.
00' 4.2 5sp
3.55
K&N air filter
single in dual out
Hope to have a superchip
soon.
00' 4.2 5sp
3.55
K&N air filter
single in dual out
soon.
Thank you buddy for the quick response. I will evaluate all this and compare with other alternatives.
Hey Clifton,
Thanks for the info on the Mop & Glo, I'll have to try it on my truck. By the way, I'm from Dekalb, maybe we'll see each other around Texarkana sometime......
2000 F-150XL, 4.2L V-6, Airaid FIPK, 5-speed, 3.55 gears, Short Bed, Black Westin Nerf Bars, Black Diamond Aluminum Toolbox, Medium Torreador Red/Clearcoat, 40/60 Split Bench, Tinted Windows, Vent Visors, Bed Mat, Overhead Console, P255/70R-16 OWL All-Season.
RussK...you were right!
No reason to search any longer for the ultimate tire shinner product because here is what it is......
McGuires "Endurance" Gel for tires
This is by far the best stuff I have ever used and smells as good as it works...Grape smell!
Goes on smooth, lasts longer than any other product I have used in the last 20years and makes my tires look like new...oh ya...no mess either!
"Endurance" from mcGuires is the tire shinner of 2000...ME VERY HAPPY!!!
2001,
I have been using the McGuires "Endurance" Gel for tires and I LOVE IT!!!!
It lasts for a long time and it looks great. I was curious why they made it smell like grape, though?!?
I just make sure that I wipe off any excess on the edges where the sidewall meets the business side of the tire and any that gets globbed up in the letters. If you don't you will find it stuck to your truck.
I have also used it on the trim around the back window (mine is turning light grey) and it made it look like new.
Thanks Guys for writing in support.
I finally wrote something someone agreed
with .. woo hoooo ... seriouly though ..
I have tried them all over the years ..
(I'm old) and for my $$$ ... endurance
is it..
Russ
1971 F-250 Camper Special Alaskan Camper
1998 F-150 Lariat S/C 4x4 5.4L Line-x Flow Master 40
2000 Explorer XLT Mach Audio SOHC
is it..
Russ
