How to remove water spots.
Old May 4, 2010 | 10:11 PM
waloro1's Avatar
Wondering if anyone can tell me an easy way to remove water spots from glass and chrome.
Old May 4, 2010 | 10:17 PM
grantcar16's Avatar
Wheel Acid
Old May 5, 2010 | 01:44 PM
birdshooter's Avatar
Something that has worked well for me is Meguiars #4 Heavy cut cleaner. While not specifically designed for glass or wheels, it does a good job of taking out water spots (especially on glass) and leaves behind a polished finish. Work it in good by hand or use a DA till product is worked in good, then wipe off (repeat if necessary). Leaves the glass clean and polished. Then if you wish you can go over it with your rain x etc. if you use those type of products.
You might also try Meguiars Ultimate Compound as this is very similiar and may be easier to find. I know Wally world stocks it.
Old May 5, 2010 | 09:51 PM
grantcar16's Avatar
Some wheel acid and a wool scronge works really really well...
Old May 5, 2010 | 11:03 PM
MarkY's Avatar
Clay bar.
Old May 6, 2010 | 01:55 AM
roushstage2's Avatar
Originally Posted by grantcar16
Wheel Acid
I think they got it. Other's are just giving equally well advice that works, albeit, a bit safer methods.
Old May 6, 2010 | 09:10 AM
Barkeeper's Friend.
http://www.barkeepersfriend.com/
Old May 6, 2010 | 07:42 PM
grantcar16's Avatar
i forgot to say the wool sponge so i just recommented.. my bad.. Plus, I build car washes and sell to all the detail places around here... Just saying some wheel acid and wool sponge wont hurt..
Old May 6, 2010 | 09:17 PM
jtwoodall's Avatar
On chrome I lightly use rubbing compound and it makes it look brand new, then go over it with a coat of wax
Old May 7, 2010 | 03:11 AM
Originally Posted by glc
That stuff works incredible on glass
Old May 7, 2010 | 03:18 PM
jzuman's Avatar
I agree with GLC and Roushstage2 on the Barkeeper's Friend!
Old May 7, 2010 | 08:43 PM
Old Dogg™'s Avatar
and it's indifferent to the rubber and plastic moldings around the windows.
Sometimes there is so much attention to the work area there is little concern for collateral damage until it too late.
Old May 10, 2010 | 03:11 AM
That's why I tested it out on someone else's car first
Old May 15, 2010 | 05:40 PM
TX_FX4's Avatar
I just asked this same question. I guess I should have searched on here a little deeper. Sorry about that. So I'm assuming that the liquid is the best bet?
Old May 15, 2010 | 06:49 PM
What liquid?
