What size pads are you using?
Old Jul 13, 2009 | 09:11 AM
pmason718's Avatar
I have a G110 and I'm using the 7" pads. Should I be using the 6.5"? I've been using the 7" pads with success so far but I'm just wondering what advantage (if there is one) would the 6.5" pads have over the 7"
Old Jul 13, 2009 | 10:18 AM
dsq3973's Avatar
I am using the LC CCS 6.5IN pads on my PC and I got decent results with it but it works the machine pretty hard if you have alot of correction to do.
Old Jul 13, 2009 | 05:51 PM
hwm3's Avatar
You won't notice any difference between the 7" and 6.5" pads. If you want to try something different, get the smaller 4" pads. They will give you more cut, and be easier on the machine.
Old Jul 13, 2009 | 08:58 PM
pmason718's Avatar
Do Megs make 4" pads? If not can you recommend some.
Old Jul 13, 2009 | 09:01 PM
abervintageman4's Avatar
look into hexlogic on chemicalguys.com i just order a 4" pad i jsut need the backing plate now, i have 2 6.5" pads, 3 5.5" pads and 1 4" pad
Old Jul 13, 2009 | 09:12 PM
1badstx's Avatar
Meg's doesn't
Justin @ obsessivedetail has a 4 inch kit of lc ccs pads
Detailedimage has flat 4 inch lc pads.
I prefer flat pads but that's just me
Old Jul 13, 2009 | 09:29 PM
pmason718's Avatar
Are you guys using these pads on the G110
Old Jul 13, 2009 | 09:40 PM
esf's Avatar
esf
4" on the 7424.
Old Jul 13, 2009 | 11:11 PM
Old Dogg™'s Avatar
On my G110 I use 5.5" CCS pads mostly...sometimes I use 4" in tight places and on my wheels. I have a few 6.5 finishing pads I use for applying wax and sealants.
Does your backing plate look like this?
Old Jul 14, 2009 | 09:05 AM
pmason718's Avatar
I'm pretty sure it does but I will check when I get home
Old Jul 14, 2009 | 10:42 AM
Spike Strider's Avatar
I used the 5.5 Lake pad on the 7424XP, and they seemed to work well. However, I have no other exp with other pad sizes.
