Did I do this in the right order?
Old Feb 17, 2009 | 06:11 PM
Ryanmc86's Avatar
Clayed
#02
#80
NXT 2.0
I am thinking that i should not have used the #02 before the #80 as it felt like it polised more than anything. BTW its a black truck and the paint had alot of swirls and scrathes. It came out pretty good regardless
Old Feb 17, 2009 | 06:13 PM
guitarman502's Avatar
If i'm right, 02 has more cut than 80. If so, then your good.
Old Feb 18, 2009 | 09:21 AM
05supercrew's Avatar
#80 would have probably done the job by it self, then Nxt. Now get a bottle of #26 to finish it off. On my black 05 Ive got great results with #80,#21, and #26 or #16.
Old Feb 18, 2009 | 02:50 PM
Ryanmc86's Avatar
Yea I was kinda thinking that. I will have to give those a try next time. Also how come #02 and #80 dont wipe off easy. Is it something im doing wrong? I eventually began misting #34 on to take them off? Is this ok? Any better ideas like work it in better or what?
Old Feb 18, 2009 | 04:26 PM
How was the weather? If it is humid out dont bother trying to detail your truck everything will dry instantly. Also when applying #80 and #2 all the work is in the application, as soon as you are done applying it remove it right away with a good micro fiber cloth. BTW what are you applying these polishes with?
Old Feb 18, 2009 | 05:54 PM
Ryanmc86's Avatar
Im using a G110. Yea it was a humid day and about 50 degrees. I ended up pulling it in the garage and turned the heat on and in about 20 minutes everything started coming off much easier, but i also was using a mist of 34 to help take it off. If i want the best results should i be using a cleaner wax after the clay or is the 80 a cleaner and polish?
Old Feb 18, 2009 | 07:25 PM
The humidity was definitly your problem, you shouldnt need #34 to take #80 off. After clay use #80, that will help remove your swirl marks, you may need 2 passes with #80.(side note #205 is suppose to be better then #80 with the same cut, I will be trying this during my next detail) Next I would use a Polish, here is were I like to switch to Poorboys polishes (your choice) If you havent tried PB you will love it. Super easy to apply and even easier to remove.(once again after you apply a polish remove it right away) After this I would go with a sealer (#21) or even better Wolfgang 3.0 this is also very easy to apply and remove. After this wait 24 hrs and do your Wax. I like #16 and now started using Collinite 845. With these steps you will be very happy. This is my normal full detail. Ever time I do another detail I will switch to other products just to see how they work. Good luck.
Old Feb 18, 2009 | 08:22 PM
Ryanmc86's Avatar
Thank you for your help and I will definatly be trying a few of those product as well
Old Feb 19, 2009 | 08:21 AM
No problem, there are a lot of people here that have some good input on different products.
Old Feb 20, 2009 | 01:52 AM
Did you like #02?
Old Feb 20, 2009 | 08:35 AM
#2 is one of those products that does the same work as #80 but not as good. I think it has a polish in it so it would leave more of a shine. I`ll tell you #2 and even better#4 is great for removing water spots off your windsheild and side windows. If you have decent clean glass #2 is good just to clean it up. If you have heavy spots that just wont come off #4 is exellent. Its going to take a little while to get everything off but when your done it will look brand new.
Old Feb 20, 2009 | 09:12 AM
What process are you using on the windows? Pad, DA or rotary, etc? I think after this winter, i'm going to have to buff my glass.
Old Feb 20, 2009 | 09:38 AM
esf's Avatar
esf
For glass, use either a rotary or hand. You'll need to apply some pressure so a DA will not work too well. If by hand, use a terry cloth towel.
Old Feb 20, 2009 | 10:01 AM
All I have is a DA thats why is took a little while but it worked. I was at the point I was going to replace my windshield and #4 cleared everything up. I tried it by hand and it didnt work. Ive tried so many other product I could have bought another DA.
