Concerns with Eshine order
Old Jul 15, 2008 | 10:57 PM
  #31
eShine's Avatar
Sure, they are on sale too! LOL
Originally Posted by ThumperMX113
Can I get a third can?
Old Jul 15, 2008 | 11:01 PM
  #32
ThumperMX113's Avatar
Well, I bought two tins and they weren't on sale !!!
J/K, keep up the good work.
Old Jul 16, 2008 | 12:46 AM
  #33
RollingRock's Avatar
Originally Posted by eShine
I can comment on my personal experience which is I have cans that are chalky whiteish blue and another regular blue. It seems as if the chalky white turns blue as you get deeper into the top layer almost as if only the top is white. I have used them both and they work the same. The cans that are real soft in the middle, customers have double boiled them, stirred and they cool consistent. I would not worry about the color myself.
Good enough for me Chris, again, thanks for jumping on the site.
Would you mind dropping me a note about another topic?
rollingrock@thedetailerscafe.com
Cheers
RR
Old Jul 16, 2008 | 01:14 AM
  #34
f-150sport03's Avatar
Gotcha. That said, I will double boil the one that is looking wierd. No worries if they perform equally...
Thanks for the quick replies and great advice!!! Duly noted for future business!!!
Old Jul 16, 2008 | 10:19 AM
  #35
jimithng23's Avatar
"Double boil"
What is this process? I did a forum search and come up with nothing...
I have 3 tins of #16 coming from eshine so any info is appreciated!
Old Jul 16, 2008 | 10:43 AM
  #36
frankiemcnoosie's Avatar
Originally Posted by jimithng23
"Double boil"
What is this process? I have 3 tins coming from eshine so any info is appreciated!
Double boiling is the heating of the wax from indirect heat. A double boiler is used to melt chocolate, cheese, candle making and stuff that would burn otherwise if heat were applied strait to the substance.
(I am not sure if this is how everyone else is doing it)
Find a pan that the wax container will sit on and boil water in that pan with the wax container on it. The heat from the boiling water will warm the wax to a striable state. Ask the wife or mom, I'm sure she will be able to help out.
Old Jul 16, 2008 | 12:25 PM
  #37
eShine's Avatar
Correct. Basically just put the tin in water on an over burner, it is better if the bottom is raised also using a shim or something. Heat the water and once the wax melts stir it then shut off the heat, leave to cool. Many do this even when their wax shrinks or cracks.
For Legal reasons... I do not recommend doing anything of the sort as the boiling pot can spill and burn you causing us a lawsuit.
Old Jul 16, 2008 | 02:14 PM
  #38
Dontcha' hate having to put this part in it???
Anywho, any word on working for you? (See my second post in this thread) Thanks!!!
Old Jul 16, 2008 | 02:25 PM
  #39
LMAO!
Shame we have to look out for dummies! LMAO!
Old Jul 16, 2008 | 03:10 PM
  #40
clambelly's Avatar
"Double boiling" is a very simple idea, based on the fact that water boils at 100 degrees celsius. If you place food in a pot, and then place that pot in boiling water, you're cooking the food at 100 degrees.
Why might you care about that? Well, it turns out that a lot of very tasty sauces and reductions are pretty sensitive to temperature, and you don't want to burn them or dry them out. See, for example, the chocolate sauce I've linked.
More generally, you can use this technique whenever you want to heat something in a pot (especially liquids) but you want to know that they won't get too hot.
So, how do we do it? Well, take a large pan or pot and put in about a 1-2 cm layer of water; heat it until it boils, and then put in a second smaller container inside. A small coffee pot is ideal, but a pyrex bowl can just as easily do the job.
Alternatively, you might run into a device called a "double boiler"; this is just a specialized pot with two layers, one which holds the boiling water and one which contains the thing to be heated. It's hardly necessary, but it can be a useful shortcut.
Note that the second bowl will be in direct contact with a rather hot surface, so if you're concerned about it burning / cracking, then you can prop it up on some supports (e.g. chopsticks, a couple of chopped carrots, or anything else you don't care about heating aggressively). Labels
(click a label to find demetri's related articles)
double boiler
double boiling
cooking technique
sauce techniques
reduction techniques
Links
Old Jul 16, 2008 | 03:25 PM
  #41
jimithng23's Avatar
WOW! Great explanation.
Thanks a lot! Now I am looking forward to seeing the look on my wife's face as I am boiling wax on her brand new stove!
Old Jul 16, 2008 | 03:44 PM
  #42
luke280's Avatar
Shipping...
Recieved my two tins this afternoon. It took 7 business days from Canada to Nebraska. Exactly what the email and website stated. Product arrived in great condition. Both are a light blue tint. Cheers!
