Door Panel Restoration
I have some donor door panels from the jyard to accompany my power window regulators. I decided that it was finally time to clean them.
I first tried to clean them with APC+ diluted at 4:1 when I got them. It didn't work so well.
SO, I decided I would try Murphy's Oil. I tried it full strength on an inconspicuous area, and it turned out great.
Time for a bucket and some water.
Ended up using about 1/3 of the bottle with 3 gallons. Kinda strong, but it worked well.
There's still some areas on the arm pads that need to be cleaned up more, but I figure I'll either replace them or get some "travel pads" to go over the top.
The passenger side is busted up a bit by the pillar. I figure some epoxy and home brew fiberglass and a good painter will cure what ails me.
-Tony
-Tony
I think APC+ works better than SG personally. But no, I haven't. There's little black spots on the crevices of the arm pads. I probably just need to spend a bit more time on them.
I feel like I accomplished something today, so that's a start.
