megs product help
Professional Polish is the best and most versatile polish available. It is an awesome Paint/Clearcoat cleaner, Metal polish, and super on Glass, Plastic, Headlight Covers, and Plexiglass. Professional Polish is body shop safe and contains no Wax or Silicones. It's perfect as the final preparation before application of a wax or sealant.
Poorboys Black Hole Show Glaze for Dark Vehicles is a wipe on, let it haze, and then buff off product. Spread with a soft, clean foam applicator,(If applying by machine, set your polisher to a low speed) and work until a shine begins to appear. Allow it to dry to a haze and then buff off with a clean, soft microfiber towel, like our DMT’s or Mega-Plush towels.
#80 is going to take care of most of your problems. If you need something a little more aggressive, get some #83 also. It's a little bit more difficult to use with the DA but it can be done. #9 is more of a swirl 'consealer' than swirl 'remover' but it has its place. As far as wax goes, I like the #21-#26 combo.
don't forget about hyperdressing!
if I order the megs DA from ADS which pads should I buy for applying black hole, EX sealant, megs #80 and #26..just want to make sure i get what I need...just dont know if I need to use the finishing pad for any of the above products..or if I can use the polishing pads for all of the above...sorry for all the questions...thanks guys
