Black Again trim shine
Old Jun 1, 2007 | 10:08 PM
Dr. Franko's Avatar
I put this Goo on my exterior Black trim and it made it look excellent.
My question is does this crap last or does it wash off like tire gizz?
(Tried searching the forum but search would not work)
Old Jun 1, 2007 | 11:19 PM
SuperLB51's Avatar
Are you talking about Back to Black?? If so it lasted pretty good on my old truck...
Old Jun 2, 2007 | 12:19 AM
Dr. Franko's Avatar
Here is the Goo, hopefully it too will last.
Old Jun 2, 2007 | 09:41 AM
I've never seen or heard of it........
Old Jun 2, 2007 | 10:16 AM
rustyzipper's Avatar
Doesn't read like it's to bad. I definitely like the idea that the product provides a "seal."
Black Again is a clear, thick lotion that goes only where you put it. It won’t run and leave residue where you don’t want it. Black Again is not a temporary fix. It provides a solution to the most common trim offenders: Oxidation, Sun Exposure, and Wax residue. From the moment you apply Black Again you will notice the difference: it cleans the area... permanently! This product is actually UV activated. After applying Black Again the manufacturer recommends placing the vehicle under direct sunlight for maximum effect! That’s because the compounds in Black Again react and respond to sunrays, making it the best UV protectant for all exterior trim. This superior UV protection gives Black Again impressive durability. Trim retains a new, ‘wet-shine’ luster long after the initial application and through various weather conditions.
http://www.autogeek.net/blackagain1.html
Old Jun 2, 2007 | 03:17 PM
SuperLB51's Avatar
Sounds promising! I may have to pick some up and try it!
Old Jun 2, 2007 | 11:42 PM
Bump.......This stuff looks promising. Anybody else ever used it before? You have to actually put in the sun to cure?
Old Jun 11, 2007 | 04:17 PM
LRG's Avatar
LRG
How's that stuff holding up so far Dr. Franko? You liking it?
Old Jun 13, 2007 | 08:50 PM
scorpio333's Avatar
I got a bottle and was pleased with it, esp on grayed trim. Did the bottom, faded trim on my Accord and it looked amazing after applying it. It also held up pretty good. In fact, that car recently sat in a foot of water for good few hours. My gf's dad got it out of the garage and when the rain washed the dirt away it still had areas that didn't look bad. I used it on the '00 fender flares (not faded) and it made them look pretty dang good. The rain did give it some problems, but not as bad as other products I've tried.
Old Jun 13, 2007 | 11:45 PM
grant5127's Avatar
I like this---------> http://www.foreverblack.com/
