How to remove wax from black trim? Help!!!
Old 05-29-2007, 08:25 AM
masonm75's Avatar
I waxed my supercrew and got a little wax on the trim for the bed and tailgate. Now I have white marks and wanted to know the best way to get rid of them. I used Turtle Wax Platinum... Thanks...
Old 05-29-2007, 10:10 AM
goldmember's Avatar
I've read that peanut butter works.
Old 05-29-2007, 05:02 PM
cookdawg06's Avatar
get a pink eraser. an eraser for a pencil. its quicker with the rectangle ones but im sure the little round ones on the ends of a pencil works as well.
Old 05-29-2007, 07:13 PM
BlueOvalFitter's Avatar
Talking
And some Smuckers jam and bread you are just missing the milk!
I use Windex.
Old 05-30-2007, 12:55 PM
LRG's Avatar
LRG
LRG is offline
I've had good results using Megs #40, takes it right off for me, plus you've just detailed the trim when you're done. Win/win!
Old 05-30-2007, 01:26 PM
Req's Avatar
Req
Req is offline
This is an easy one.
I use a toothbrush with a very small amount of water. Works every time.
This is an ongoing problem to apply waxes/polish near trim. To avoid most of this I use straight edge pieces of metal, with the edge blunted with duct tape. I place the blunted metal edge in the groove where the trim meets the paint, then apply the wax/polish in approx a 3" area the length of the vehicle section being worked on. The metal is easily purchased from hardware stores as household flashing.
Old 05-30-2007, 02:06 PM
rustyzipper's Avatar
Very cool idea Req. Very cool. I like it.
Old 05-30-2007, 02:59 PM
Gipraw's Avatar
I do the same thing with a painters edge, covered in tape ..
Old 05-30-2007, 09:05 PM
Heith's Avatar
I use mothers back to black you can get it any walmart, or auto parts store. The best way to use it is apply it to black plastic before you wax and the wax will not stick. But if you happen to get it on your plastic from previous waxings use it with a bit of pressure and it will work it out.
Heith
Old 05-31-2007, 10:51 PM
cookdawg06's Avatar
id beware of the back to black. although i have never used it, i have heard bad reviews from the big guns on here. i.e. rockpick, gipraw, and rollingrock and more. Basically it works good at first then forms a milky residue. You can search it if you'd like.....
Old 06-01-2007, 01:27 AM
Where's the ole spit on the end of the finger trick?
Quick Reply: How to remove wax from black trim? Help!!!
