Cleaning the headliner
Hey guys (RP you better be reading this
Any advice for cleaning headliners? Mine's got a few spots on it that I'd like to take care of. A wet rag did an ok job... Could I just use the steam cleaner at home and do it that way when I shampoop my carpets? Any advice/ideas?
),Any advice for cleaning headliners? Mine's got a few spots on it that I'd like to take care of. A wet rag did an ok job... Could I just use the steam cleaner at home and do it that way when I shampoop my carpets? Any advice/ideas?
I typically go over this with perspective or current customers... I don't touch headliners...
A couple of reasons...
1. The fabric is about as thin as it comes. Any abrasion across it can cause it to 'ball up' and/or will show the abrasion -- and there's no fix other than replacing the fabric.
2. The glue that holds the headliners on doesn't play well with moisture. How many times have you seen a headliner that has given way and is flapping in the wind? Moisture was a big cause -- that and age.
But, since you called me out individually and I've been avoiding AOL IM like the plague, I'd do exactly what you did -- a VERY lightly moist towel and a light blotting motion with a 'twist' as you touch the liner.
I've had simple green stain/dye green before...I've always used folex on fabrics and upholstery without any bleaching or additional staining. Food for thought.
Gosh you're slow.
If it's not a main seating panel - it's pleather.
1:1 mix of Simple Green & Water. 3:1 if it's stubborn. Be patient and let the chemical do the work.
Thanks bud, I'll give it a try.
