keeping your wheel well clean
Old Feb 10, 2007 | 04:32 AM
matthewfedex's Avatar
what are you guys doing to keep your wheel well clean and not looking dirty? do any of you spray it down with anything special? washing it when i wash my truck just doesnt give it that "like new" look i'm hoping for. any adivce?
Old Feb 10, 2007 | 05:44 AM
NASSTY's Avatar
Cheap tire shine.
Old Feb 10, 2007 | 06:45 AM
what about to remove the dirt and grim?
Old Feb 10, 2007 | 07:07 AM
themetermcse's Avatar
I use one of those garden nozzles that has a high pressure angle sprayer on it. I hose it off really good, then take a brush I use on the wheels and tires and go over the area pretty good.
for the front wells, I do like nassty said, just use a cheap tire shine. for the rear ones, i use a bug/tar remover to finish the job. I use the 3M stuff, (black and green bottle) and it works pretty good. Since those wells aren't glossy, just painted, I'll use some cheap wax on them to give them a more uniform look.
Old Feb 10, 2007 | 01:23 PM
qadsan's Avatar
First spray the wheel well with a degreaser like Simple Green or some type of APC (All Purpose Cleaner). Scrub inside the wheel with a stiff bristled nylon brush and hit the shocks / coils / lines, etc, with a softer long bristled brush. Hose it off and repeat if necessary until it's clean. Once the area is dry, then spray it down with a tire dressing product as mentioned above. Meguiar's Hyper Dressing diluted works very well, but you can use Armorall original shine, No Touch, Black Magic, etc. I currently use a water based dressing from Optimum after I spray / wipe down the painted surfaces with Aquawax.
It's the same with your tires. Make sure to clean them first with an APC & a brush, then apply your favorite tire dressing after the tire is dry. I simply spray a foam tire applicator with my dressing (Optimum) and wipe it around the tire. A little dressing goes a long ways when used this way. Then I'll wipe off any excess dressing and quickly buff the tire with an old microfiber which leaves a nice clean matt surface and she's good to go (no sling, etc).
Old Feb 10, 2007 | 02:21 PM
Rockpick's Avatar
Moderator &
I use the method as qadsan described but, rather than using any dressing that I really 'like', I typically reserve the wheel wells for dressings that I've purchased or been asked to try that I don't like.
My wheel wells are where dressings that didn't like go to die.
Old Feb 10, 2007 | 07:26 PM
f-150sport03's Avatar
I hit them (they're rubber for me, don't know what yours are)...with Bleache White and a nylon brush. After that, they get a coating of the cheapie tire coating.
Alternately, you can use underbody coating (a good idea anyway) and paint them. (I've done this too, ad it makes a huge difference)
Old Feb 10, 2007 | 08:45 PM
04 RED LARIAT's Avatar
I am extra **** about my wheel wells and under carriage. I spend hours to keep it like new.
What I start with...
Old Feb 10, 2007 | 09:14 PM
Rockpick's Avatar
Moderator &
I so want a steam genie.
Old Feb 10, 2007 | 10:21 PM
built54's Avatar
amazingly clean!
Old Feb 10, 2007 | 10:23 PM
What did you use to give it that "shiny" look?
I had my Dakota's underbody pro painted with a high gloss DuPont Midnight Black... it looks awesome! But it cost me a small fortune and since my F150 is my daily driver, it probably wouldn't be worth it and there is too much to paint.
Old Feb 10, 2007 | 10:26 PM
Lumadar's Avatar
They don't seem to be available in the US.
Old Feb 10, 2007 | 10:28 PM
Rockpick's Avatar
Moderator &
They're available... just pricey. Not worth my investment for the client base and amount of typical 'grunge' that I deal with...
Old Feb 10, 2007 | 10:42 PM
Meguiars Hyper-Dressing, but any tire dressing will work.
Next time you are doing some work up this way drop in. You are welcome to mine anytime.
Old Feb 11, 2007 | 07:47 AM
medic2586's Avatar
Talking
check out griot's garage....he has all kinds of cleaning supplies including a special cleaner for those of us who are "****" about our wheel wells
part#11138 Undercarriage Spray.....i've bought several items from him and well pleased with all of them
