window sticker
Old Nov 17, 2006 | 12:45 PM
FX4Firefighter's Avatar
window sticker
i want to get rid of that little sticker in the pass coner of the windshield ssaying where the truck was mad at i tries a razor still wont come off any ideas on it.. its not as bad as the dealer sticker on the tail gate but i hate advertising for peoplr who dont pay me
Old Nov 17, 2006 | 05:39 PM
Richard D's Avatar
Get yourself some Goo Gone and put it on the razor blade. Then slowly start working an edge of the stocker. That should allow you to get it off. Once off clean with some denatured alcohol.
Richard
Old Nov 17, 2006 | 05:46 PM
FX4life's Avatar
the way i get reall gooey, sticky crap off the window, (i.e reg. stickers, factory stickers.) just scrap off the paper part with a razor blade and then get some stoner invisible glass cleaner, spray it on the sticky stuff still on the window and use the razor blade to scrap the sticky stuff up. it should start to come up more and more with each pass of the razor blade. I usually have to spray it a couple of times and just keep workin it till there is very little sticky left and then get a paper towel and clean it up real good. that should do the trick, it always has for me. hopefully my instructions are understandable, if not let me know! good luck
Old Nov 17, 2006 | 07:17 PM
Gipraw's Avatar
another trick that works on glass that is not coated.. once you have scraped the sticker off as best you can with a razor blade.. take a piece of duct tape, and put it on the glass over whwere the sticker was .. (leave yourself a buddy tab). rub the duct tape very well, like you are applying it to the glass permanently .. pull it off quickly, and it will pull a lot of the left over adhesive off with it ..
then you can clean he rest up like Richard mentioned.
Old Nov 18, 2006 | 09:45 AM
thanks all now when i get off work this weekend i am going to give my truck a little extra detail since old man winter is right around the corner
Old Nov 18, 2006 | 11:36 PM
f-150sport03's Avatar
WD-40 is probably the best adhesives remover I know of. That is, if you don't mind you interior smelling like lube...
Old Nov 26, 2006 | 09:59 PM
ws6_guyscrew's Avatar
I was wanting to do this to my F150, glad I dropped by to hear some tips!
