Windshield Question...
Old Oct 10, 2006 | 08:48 AM
05supercrew's Avatar
Originally Posted by RockPick
Water spots or what?
While I don't condone the use of products such as Soft Scrub or Kaboom on an automotive surface, I'm quite confident that you could successfully use such a product pending that you used the UTMOST of care to not get it on paint, trim, moldings, etc...
In short, I'd recommend spraying a little 'Kaboom' on a shop rag while standing away from your vehicle and using it to wipe down the glass...
Again, this is a USE AT YOUR OWN RISK scenario...
-RP-
I tried these products yesterday, no good. The windows are clean, no dirt or anything is coming off and the window is smooth. You can see all the water spots because of the tint on the windows. Also the truck (blk screw 05) is fully detailed so the windows stand out even more. Can I use steel wool, I dont want to scratch the window. Thanks for all your advice so far.
Old Oct 10, 2006 | 08:54 AM
Rockpick's Avatar
Moderator &
Kaboom didn't touch it? Have you had any paint work done on this vehicle previously?
Does the glass feel etched?
Old Oct 10, 2006 | 09:08 AM
Nothing worked, The windows are all smooth. This is all 4 door windows that have the spots. I had the passenger side bed painted a year ago on halloween after it got egged. I even tried a de-greaser. I was even thinking about rubbing compound but Im worried about scratching the window.
Old Oct 10, 2006 | 10:43 AM
Gipraw's Avatar
try a little bit of Bon Ami in the lower corner, as a test. put a little on a damp sponge, and do not use too much pressure, and don't get it on your paint. I have had very good luck with it on very stubborn glass, but this is a try at your own risk option, because you can definately cause some damage if you get over agressive.
again.. be very careful, this is not without risk, but it might work for you
Old Oct 10, 2006 | 10:50 AM
Thanks a lot, I know I have that at home. Ill try it tonight. Thanks again
Old Oct 11, 2006 | 01:16 AM
NASTY-FX4's Avatar
Clean with Windex and apply Rain-X wipes.Works awsome.
Old Oct 11, 2006 | 02:03 AM
you can always gently wet sand with a very fine grit paper...
Also heard of ppl claying too.
I usually just scrub the windows down real good with my usual car sponge, but im 6'6" with a lowered truck so i can easily scrub the entire window without climbing a step stool, or getting all soaked from leaning against the truck.
-Patrick
Old Oct 11, 2006 | 09:31 AM
I tried the Bon Ami last night and it helped very little, so at this point Im going to have to say the windows are etched even though it doesnt feel like it. So my question now is, is there a different approach to dealing with etched windows? Is wet sanding an option? Every time I try one of these abrasive cleaners I always clean the window with Stoners glass cleaner to make sure the glass is clean.
Old Oct 11, 2006 | 10:23 AM
Gipraw's Avatar
one of my Georgia friends used this kit on his car, and said it worked wonders .. I have never tried it, but his judgement is usually pretty good ..
although he does drive a dodge
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Old Oct 11, 2006 | 11:05 AM
PaleRiderosu's Avatar
Gonna sound funny, but you can also use newspaper right after a good glass cleaner... The newspaper is just barely abrasive enough that it pulls a filmand most water spots off, and really polishes up the glass. One of my buddies also used a coregated cardboard thing on glass and says that works really well for removing some bug guts etc... Personally i have never tried it..
Old Oct 11, 2006 | 11:19 AM
Thank you, The spots almost look like they are ghosted into the glass so this might help. It will be a few weeks before I can try it but I will.
