How to keep textured plastic clean while waxing?
I am going to wax my truck this weekend and it has alot of textured plastic, fender flares, box rail caps, steps on box sides, ect. I heard of a trick to keeping them clean when waxing so that they don't end up with a white film on them, but I can't remember what it was. Can someone help me out??
Thanks Paul
Thanks Paul
I have the same problem! It is nearly impossible to not get wax on the plastic while waxing. I have heard of putting something with oil in it (baby oil, armor all) on it before waxing so when the wax hits it you can wipe off.
I think RockPick can come up with a good idea!
The new F150's have quite a bit of plastic on them. When you are using a buffer to apply the wax its hard to get the grooves without hitting the plastic in some spots.
I have only used the machine once on my truck, and the other times i just applied by hand.
I guess painters tape is the way to go
removing white wax chalk from textured plastic
Peanut Butter, I've heard it for years, tried it a month ago on my door handles
I got a little amount of peanut butter on my finger, rubbed it in, and wax chalk was gone.
The Peanut Butter sounds like a mess! Are you sure the oils in the peanut butter are not just temporarily covering the wax up? Or does it acutually lift the wax off.
I may have to try. I think I heard you mention this in another thread awhile back.
I have several pieces of sheet metal ( house roof flashing works well). At the edge of the sheet metal I have a strip of duct tape to protect the pickup paint. I place the taped metal between the textured plastic and the paint to be waxed. It works well and the metal guards are alway there for a repeat performance. You can also trim out curved patterns with the sheet metal for those curved surfaces.
Where I do get some slight wax on the textured plastic I simply use a tooth brush dipped in water. Works fine.
Peanut butter is a temporary solution, the white chalky wax will reappear. The oils in the peanut butter basically mask the wax for a short period of time.
I use painters tape and if I still manage to get any wax on the plastic I get out an eraser.
- Chris
- Chris
Well, I ended up detailing the truck today. 6 hours later I am finally done.... I used the 3M painters tape (blue) for mask off all the plastic, and on my truck a FX4 Flareside there is tons of it. I think more than any other truck, it was a pain but is done. Thanks for all the hints!!
Paul
Paul
Painter's tape is what I use, but if you still manage to get some on, you can use a Mr. Clean Magic Eraser, but BE VERY CAREFUL, because it can cause some damage. Only use it on the textured stuff too.
