Hand waxing technique
Old Jan 25, 2006 | 09:45 PM
  #46
mack4000's Avatar
Originally Posted by Boss_429
There is some good advise at those sites. Also a lot of "bad advise", a lot of "product pushing", a lot of "nonsense", and a lot of folks with "agendas".
Boss, is there an honest detail site/forum that you recommend?
I'm dying to learn more.
Old Jan 25, 2006 | 10:01 PM
  #47
Rockpick's Avatar
Moderator &
Originally Posted by fmdog44
So,...........you are saying you can look at several different vehicles waxed with different products and you can tell what as used. Please!!!!!!!!!!! A good paint foundation will yield the exact same appearance from any good wax/polish. Period!!!!!!!!!!
Huh? Where did I say I could tell 'what products were used'? Let's avoid putting words into my mouth... um k? I don't think the best of the best of the best could look at a surface and pick out the product used... give me a choice of three and I might have a shot though. -- I'd probably still miss it though.
No one in their right mind would make such a statement... re-read my response to yours earlier in the thread please.
Secondly, as Boss alluded to, I simply said that a trained eye can, without a doubt, tell the difference between certain products when used side by side on a vehicle. Honestly, I think you could too if you tried a simple 'side by side' test with a full synthetic LSP on half of a hood and then a carnauba based LSP on the other half... in fact, it's VERY distinct -- even on whites and other light colors!
While you have very good merit in saying that a good 'foundation' (assuming your talking about the proper preparatory work on the painted surface before going with a last step product) is important on any 'detail job', I still, whole-heartedly, disagree in that all products will have "the exact same appearance from any good wax/polish." Sorry bud... it's just not the case.
Old Jan 25, 2006 | 10:05 PM
  #48
Rockpick's Avatar
Moderator &
I'm not Boss but I'm going to take a stab at this if you don't mind (and I think Boss will agree with my stance on this...)
None of them are perfect. Any type of public forum will yield folks that give bad advice... most, as well, will have some folks that yield excellent/top-notch advice...
The best advice is this... surf oodles of them and soak up as much as you can. Once you've managed to soak up the info, make inferences back and forth to see the consistency across the sites... from there, attempt to give it a try (this is where a 'junk yard hood' comes in VERY handy!!!).
There's OOOOODLES of detailing sites these days... and, in all honesty, many of the same folks frequent them all individually so, keep that in mind too.
RP
Old Jan 25, 2006 | 11:45 PM
  #49
runnerbl's Avatar
Some give a shiny, bright look then there are others that give depth, wet, glossy look. As Boss and RP said...a difference can be seen. Just havta know what you are looking for.
Old Jan 26, 2006 | 01:05 AM
  #50
mack4000's Avatar
RP
Thanks RP. I have been going to a few different forums (meguiar's, autopia, etc.), but, to be honest, I have found this forum to be the best environment in which to learn so far.
The only way to know what works the best is to try it. I guess I need to find a good site from which to order samples. I don't like experimenting by buying gallon sized bottles!
Old Jan 26, 2006 | 08:43 PM
  #51
Rockpick's Avatar
Moderator &
Let us know if you see a product that you're wanting to try... someone here might know of a place that would either send you a sample or have a 'sample sized' portion for sale...
Unless you're working in to the products that are strictly detailer bulk, you shouldn't have a problem buying 'consumer sized' amounts...
RP
Old Jan 26, 2006 | 10:13 PM
  #52
mack4000's Avatar
RP
I wanted to try some of the Detailer line products like Hyper Dressing, APC, and Wheel Brightener. I found smaller sizes at ADS. They seem to be highly recommended on the site, so I think I will give them a try.
Let me know if you recommend any other sites with smaller sizes or trials of Meguiar's products. Thanks!
