Removal of dealership logo
Old Feb 22, 2005 | 07:54 PM
TruBluSuperCrew's Avatar
Question Removal of dealership logo - Updated!
I was just curious, if you are able to remove the painted dealership logo on the tailgate of the truck? I was hoping if there is an easy way to do this, or am I stuck with it until I ever decide to paint the truck. Any help would be appreciated.
Update:
Thanks guys for all of the info. I was able to use the hair dryer and it came right off. After a little buffing and using some Meguiar's Quik Detailer, looks like there wasn't a logo there, just like I wanted. Thanks again.
TruBlu
Old Feb 22, 2005 | 07:59 PM
RockyJSquirrel's Avatar
Most of them are stick-ons. Grab your wife's hairdryer and warm it up, then you should be able to peel it off (careful, it's hot). Then you should be able to buff/ polish out any remaining marks.
Old Feb 22, 2005 | 10:36 PM
Rockpick's Avatar
Moderator &
What he said!
It's probably not painted on (way too much expense for a stealership to have them done that way)... It's probably vinyl or adhesive.
The vinyl ones peel off nice and easy... some of the adhesive ones are a bit more contrary.
RP
Old Feb 23, 2005 | 10:50 AM
max mitchell's Avatar
Heat, thumbnail, and 3M adhesive remover on the remnants.
Old Feb 23, 2005 | 10:36 PM
Thanks for all of the info, hopefully the weather will get better for me to try it.
Old Feb 24, 2005 | 05:03 PM
straps's Avatar
There is also a wheel that you use in a drill that shops use to remove pinstripes. Sort of like a big eraser. I think that 3M makes it and you can get it at an auto paint store.
Old Feb 24, 2005 | 07:17 PM
Jordan not Mike's Avatar
i'd get rid of it quick, before your paint fades at different rates and then you're stuck with an outline/ghost of the sticker in your paint...
