Over Spray
Old Jul 18, 2003 | 08:46 PM
2002FORDFX4's Avatar
Angry Over Spray
Does anyone have or heard of a product you can get at a local store that will SAFELY get light over spray off of paint WITHOUT taking the paint off with it? I just figured something like that would be out there.
Thanks!!
Old Jul 18, 2003 | 09:29 PM
01 XLT Sport's Avatar
YES, a claybar will remove it very easy, and not hurt your paint at all...
Any good claybar will do. You should be able to find one at a local auto parts store. You want to use a good luburcation with the clay, usally the best way to do it is to use a bucket you prepare for washing your truck. Put the soap and water as you would for washing and use it as the luburactaion for the clay.
The important thing to remember, or recommendation is to cut your clay bar into say 3 pieces. If while claying you happen to drop it then THROW AWAY that piece, do NOT try to clean it just THROW IT AWAY. Once your done claying wash your truck and wax/polish the area you clayed so as to protect the paint.
If you need more information on claying then just ask...
Old Jul 18, 2003 | 09:30 PM
Tailgator's Avatar
Use a clay bar, it will remove light overspray & just about anything else that's embedded in the paint without damaging it!
Old Jul 18, 2003 | 09:58 PM
Rockpick's Avatar
Moderator &
Clay is the way!
Old Jul 18, 2003 | 10:03 PM
Go the way of clay...
Old Jul 18, 2003 | 10:04 PM
Rockpick's Avatar
Moderator &
Do what we all say.... stick with clay.
Old Jul 18, 2003 | 10:09 PM
Clay time is like play time...
Old Jul 18, 2003 | 10:12 PM
Rockpick's Avatar
Moderator &
This is getting silly...
Old Jul 18, 2003 | 10:13 PM
You started it, of course now 2002FORDFX4 thinks we are all nuts so may have went and joined another Ford site thanks to you...
Old Jul 18, 2003 | 10:15 PM
Rockpick's Avatar
Moderator &
Nah, this is the one and only Ford site..... well, the only one that's worth a flip.
All the other sites want to talk about is stereos and superchargers... sure, they're nice, but I have other interests.
RP
Old Jul 18, 2003 | 10:44 PM
I concur...
Old Jul 18, 2003 | 10:47 PM
Boss_429's Avatar
2002FORDFX4,
If you're still with us, be advised that some overspray can be difficult to remove with a clay bar. Having said that, some manufactures of clay bars have different grades of clay bars to handle different jobs. For example, Clay Magic had a blue bar, and a red bar. The Blue bar is less abrasive than the red bar, and will not remove overspray that the red bar will. Keep in mind that the more abrasive bars can cause some swirl marks, so you may need (and should) polish after using a clay bar.
Good luck getting the overspray off!
Old Jul 18, 2003 | 11:43 PM
bloomquist's Avatar
Go with clay!
Old Jul 19, 2003 | 09:07 AM
Originally posted by Boss_429
2002FORDFX4,
I didn't know there were different types of clay. The only clay bar I have used is the Zaino clay bar, which I figured was nothing better then the good quality ones bought in the store. Mine took off my overspray with no problems and has never left any scratches, so you may want to consider the Zaino claybar (Z18):
http://www.zainostore.com/Merchant2/...ory_Code=Zaino
Old Jul 19, 2003 | 10:01 AM
Boss_429's Avatar
01,
Actually, the Zaino clay bar is an excellent clay bar. I believe it's the same bar as the Pinnacle Poly clay bar, which is considered one of the best. IMHO, either of these bars is better than some found in local stores. However, there are only a few manufactures of clay bars, so, in reality, some of the clay bars are identical, even though they have different labels.
