Power plug don't work
Old Feb 14, 2003 | 06:12 PM
angus's Avatar
Unhappy Power plug don't work
I blew the fuse for my Cigarett lighter replaced fuse lighter works but the power supply beside it don't can anyone help me with this.I like to use it for my cell phone.
Old Feb 17, 2003 | 09:24 PM
Rockpick's Avatar
Moderator &
Hard to say but, have you checked the power cord itself? Most of the newer cigerette lighter cords have their own 'in-line' fuse built into the plug portion of the assembly. You might have blown a fuse in the cord. If so, replacement is as simple as running to wallyworld and buying a fuse.
You might try plugging another 12v item in and seeing if it works.
Good luck.
RP
Old Feb 17, 2003 | 10:09 PM
angus's Avatar
I have checked it there is no power the cigarette lighter works but hw power outlet don't are they on the same fuse.Or are they seperate
Old Feb 17, 2003 | 10:25 PM
Rockpick's Avatar
Moderator &
I'll try to do a little research for you but, I'm really not sure I'll be able to dredge up any information.
Hopefully, someone is going to come along and give you an answer... I wish I knew it...
I'll try to check it out!
RP
Old Feb 19, 2003 | 07:01 AM
bluemesa159's Avatar
I did the same in my 1999 F-150.... if memory serves, I had to replace one of the big fuses under the hood. I'm 6,000 miles away from the truck right now or I'd run outside and check.
Old Feb 19, 2003 | 11:24 AM
SSCULLY's Avatar
Just got a chance to look it up.
Per the EVTM, the Aux power socket is fuse #1 ; 20 amp in teh battery junction box ( under the hood fuse box ).
The Cigar lighter is in the central junction box fuse 3 which also supplies power to the DLC and RAP module.
so it seems there are 2 different fuses for each plug.
FWIW : For a SCrew the rear power point is yet another fuse # 12 in the battery junction box.
Hope this helps
Steve
Old Feb 19, 2003 | 12:39 PM
Rockpick's Avatar
Moderator &
Steve is da man!
Angus, looks like you might owe Steve a 'frosty beverage' just like I do... LOL!
RP
Old Feb 19, 2003 | 12:55 PM
angus's Avatar
Wink Thanks
I just want to thank everbody that helped with the power plug
problem.I just had some dental surgery when i feel better i will check it out thanks again i love this board.
Steve you are the Man
Problem Solved thanks to you guys thanks again for the help.
Old Feb 19, 2003 | 01:00 PM
SSCULLY's Avatar
No one owes me anything. If it is beer for payment, then I'll have to reassign a whole bunch of these "IOUs" to other members.
Looks like Neal, JMC, TexFordD, AJ and a few others are going to have beer for a year if this is the case
I get this stuff by reading way back, so it is all in here somewhere, it is just a matter of going back far enough to read it all.
Also I think at least 2 are needed for the corrective lesson in Thermodynamics
Good luck, hope you feel better
Steve
Old Feb 19, 2003 | 07:56 PM
Rockpick's Avatar
Moderator &
Sounds like we need to just get together and have a 'kegger'.
RP
