Bedliners, Caps, Tops & Lids
Holes in tonneau cover
Old Oct 12, 2012 | 04:02 PM
Sky Cowboy's Avatar
Ok so I bought my truck about a month ago and it has an ARE tonneau cover on it. The previous owner must have had some kind of wing mounted to it and removed it. There are 5 holes (approx 1/4" each) drilled through the cover and i'm looking for suggestions to fill/plug them then go over it with touch up paint. I have been thinking bondo or kitty hair but not sure how it will hold up to the temperature differences between seasons here in Kansas without some kind of backing to bond to. Thank you in advance!
Old Oct 12, 2012 | 06:07 PM
beechkid's Avatar
25 Year Member
Fibergalss patch on the backside, taper the hole edges, then fill with a fiberglass filler, block sand, prime, paint.
Old Oct 12, 2012 | 08:55 PM
Sky Cowboy's Avatar
Thank you Beechkid I will try that.
Old May 27, 2020 | 03:38 PM
onebadfiveoh's Avatar
Wrong thread. Sorry about that.
Old May 27, 2020 | 06:10 PM
Something tells me you didn't intend to reply to this thread................................
Old May 27, 2020 | 06:12 PM
I see what happened. Thanks glc!
Old Jun 11, 2020 | 02:03 PM
tbear853's Avatar
here in 2020, screen wire & flexseal.
