Bedliners, Caps, Tops & Lids
Line-X, now tailgate hard to close
Old Mar 31, 2008 | 01:02 AM
dfwtaxman's Avatar
I just had Line-X sprayed in my '08 F150 and it looks awesone. Had the color matched xtra with a King Ranch logo stenciled on the bulk head. The only problem is that the tailgate is now "tough" to close. I realize that the Line-X is adding material and will close the gaps, but is this normal? The tailgate used to gently click to close, but now I have to give it a decent shove. Any help would be appreciated. Thanks.
Old Mar 31, 2008 | 07:34 AM
NCSU_05_FX4's Avatar
Take some pictures for us...
I have no issues with closing mine, most people don't. Maybe they sprayed where they shouldn't have, or maybe the sprayed it too thick around the tailgate area. Hard to say without being able to see it.
How much did the Xtra cost? I'm thinking of doing my bumpers and rocker panels.
- NCSU
Old Mar 31, 2008 | 07:51 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
See post #4.
https://www.f150online.com/forums/sh...d.php?t=289619
Old Mar 31, 2008 | 08:29 AM
dfwtaxman's Avatar
- NCSU
The spray appears to be about 1/16-1/8 thick. But 1/8 on both side is now 1/4, so I can see where it may be a little tougher to close. I'll try and take some pictures.
The Xtra cost and additional $200 - above the base $450. Out the door it cost a little over $700. Pricey but definitely worth it for the color match. This is in the DFW area.
Also, can you adjust the tailgate latches or am I better off just to give it a little extra shove to close? Thanks for the input.
Old Mar 31, 2008 | 03:04 PM
No problems with the line-x here, my gate opens & closes with ease.
Old Mar 31, 2008 | 04:34 PM
TruckGasm's Avatar
1. On the tailgate, check the latches on both sides of the tailgate to make sure they are clear.
2. The tailgate latches latch onto posts. The posts can be loosened, adjusted, and re-tightened. Sometimes the posts leave a mark on the paint of their original position.
Chances are the posts need adjusting and the bedliner is OK.
Old Mar 31, 2008 | 11:02 PM
dfwtaxman's Avatar
Thanks! That worked like a charm. My gaps on the tailgate are now a little wider, but at least there's a gentle "click" to close the tailgate. I'll save the gap issue for another day. Thanks, again.
Old Apr 1, 2008 | 01:05 PM
TruckGasm's Avatar
You know, some truck's tailgate lines up with the body, some don't no matter what the brand. You can have two identical trucks side by side and one may line up better than the other. I can tell you that Toyota is the worst as far as consistency in lined up tailgates.
Old Apr 6, 2008 | 06:55 PM
OrdnanceCorps's Avatar
line-x
