Bedliners, Caps, Tops & Lids
RollBak Owners, Please sign in: calling Tuff4rd,Jimmy K, BalogUK, Heavy2804
Old Jun 10, 2007 | 05:58 PM
knighj1's Avatar
They did have a price increase they also were back ordered for a week or two also, Im still waiting to get mine, but no big hurry b/c the truck has yet to arrive, suppose to be here tomorrow
Old Jun 23, 2007 | 12:31 AM
knighj1's Avatar
Ken did your front cover seal the gap?? I finally installed mine and their is a gap large enough in the front to allow leaking, but maybe it will run into the bucket and drain????
Old Jun 23, 2007 | 10:03 PM
knighj1's Avatar
Did you all get any LUBE? I did not what kind of grease do I need to use?
Old Jun 24, 2007 | 02:53 AM
Ken07Harley's Avatar
If you're talking the gap at the front of the bed next to the cab... no mine does not seal. The gap appears to be the size of the height of the plastic bed rail caps. My plan is to put a weather-strip in there to fill the gap, but not until I get my spray in bedliner done.
Old Jun 24, 2007 | 02:55 AM
No lube was supplied. But they recommend WD-40. I would not use a grease. Just WD-40 or a silicon spray.
Old Jun 24, 2007 | 11:32 AM
knighj1's Avatar
I went to advanced auto and got some cmper top seal I think it was 30 yards for 11.88 and I ended up putting 5 on top of each other and this provided a top seal, I now just have to drill the hole for the drain tubes
Old Jun 24, 2007 | 11:38 AM
BalogUK's Avatar
knighj1, if you've got a gap, move your left and right tracks back as far as you can, while still being able to close the tailgate- if you do this, you have to shut the gate harder, but you will have a 100% weather-tight seal provided by the rubber on the end of the cover...
Old Jun 24, 2007 | 12:26 PM
Don't drill the bed itself for the tubes. Look at where BalogUK put his.
Old Jun 24, 2007 | 12:46 PM
BalogUK's Avatar
same on other side...
Old Jun 24, 2007 | 09:32 PM
knighj1's Avatar
I just took those pieces out b/c there was no way to get them out and back in after installing the bedrug, also the gap was at the front of the bed near the cab, the rear seems fine. Thanks for all the help guys
