Best Bedliner 200-300 range?
Got quoted around 450 for line-x. Rather spend the extra money elsewhere but want some sort of a bed liner. Have been without for a yr now on my 05 supercrew and am ready to make the purchase. Bed doesn't look to bad for a full yr of moderate use. Bed is of course 5.5 ft. Looking for something that is going to last, as far as durable I really only put the occassional plastic garbage can,some house items and my atv. This is not a work truck. Oh and I already have the side bed rails and a plastic strip on the tailgate.
Also am considering the extang tilt cover so the weather shouldnt be a factor.
Not a lot in that range, other than drop-ins. Might check out DualComp - only a couple dollars more and heavier duty than the rest. And yes, I am somewhat biases - after driving trucks for some 28 years and wrecking all sorts of bedliners, I found DualComp worked so well that I joined the company.
Plywood and a can of tremclad rust paint, 5/8 floor sheating works the best, you can cut 2x4 and use 3/4 N8 screw's to secure your load from sliding around, or use the slats in the box and extend 2x4 the width of the box, screw the ply wood on top of the 2x4 verry cheap and allows you storage underneath ( depending on high you riase the 2x4, 2x6 ect in the slats )
I have this set up on my 04 F-150 works great
why not just a drop in PENDA liner. I had one in my previous truck for over 100k miles and it was fantastic. It offered the non-skid surface and only cost $199 with installation. Looks great and it very durable. i just put one in my 06 yesterday. as far as i am concerned its the best product for the money.
The Duraliner that comes factory in them fits, functions and looks much better. Cheaper too.
I have the factory Dura-liner with Ford logo at the front. Works great, and easily cleaned. Also, the plastic of it hasn't distorted by any means. I think it was pretty cheap too, got it with the truck brand new.
