Bedliners, Caps, Tops & Lids
Light Installation Within the Bed
Old Mar 30, 2005 | 02:09 PM
  #31
hawkfxr724's Avatar
Hot wire ??
Is there a hot wire at the trailer hookup? If there is, that'd save a ton of time and trouble.
As to the switch, Snappy's got the right idea! If you don't have a rigid bedcover, a rocker switch is the way to go. It looks like you can even order them straight from the manufacturer. I like the ones with the LED light in the switch, although that would probably drain the battery, being on all the time.
Great ideas, you guys..we'll think this sucker out in no time!!
DC
Old Mar 30, 2005 | 02:13 PM
  #32
vader716's Avatar
I read another post that seem to indicate there was (hot wire). Seems to me it may only be hot when you turn on at least the parking lights but I haven't tested it.
Even that setup would be ok with me but it is worth checking in to.
Just not sure if the wiring and fuse could handle the extra load.
Old Mar 30, 2005 | 07:59 PM
  #33
snappylips's Avatar
Originally posted by vader716
How possible would it be to tie in to the hot wire from the towing package? That wire is already at the back of the truck and would save from running wire direct from the battery.Jim
Hey Jim, As far as I know, there is no hot lead at the trailer connector. Even if there was, I wouldn't tap into it. I want no splices in my wiring at all, but that's just me.
SL
Old Apr 2, 2005 | 10:51 PM
  #34
MnFatz's Avatar
Here's what I'm going to try.
I collected a bunch of server indicator lights from work. They're LED's in a slick little cast aluminum housing that has a clip on them. They're status indicator lights for Dell 2650 servers that no one bothers to use. Until now! I've got 17 of them complete with pigtails.
I went to Lowes and bought two 5' lengths of very thin aluminum to serve as the rails the LEDs clip onto.
My plan is to clip the LEDS onto the piece of aluminum and cover the entire length of the aluminum strip (except of course for the lights themselves) with heat-shrink tubing. A few strips of velcro strategically placed in the bed and on the aluminum strip, and I should have a pretty nice lighting system. The only drawback is this system is going to require a transformer.
I'll make sure and post pics when I get a good start on the project.
-Fatz.
Old Apr 11, 2005 | 09:25 PM
  #35
hawkfxr724's Avatar
Question Just curious.....
Did anyone ever get to install the lights in their bed??If so, how does it look/work? Are you pleased?? Give us the report!!
DC
Old Apr 12, 2005 | 12:06 PM
  #36
dean1614's Avatar
Bed lights
http://users.cableaz.com/~kinzerford...150_Entry.html
ROCKPICK, check out this guys (one of the members)
I bookmarked his page because he has some great mods.
enter the site and scrol down to the lighting section. instructions of how he illuminated his bed
Old Apr 12, 2005 | 12:39 PM
  #37
dzervit's Avatar
Now that the warm weather is back, it's time to re-visit this mod...
Old Apr 20, 2005 | 10:09 PM
  #38
bryanfeelsgood's Avatar
I just got a set of $12 fog lights from Wal-Mart, I am going to mount them inside on the lid of my truck box.
I will use the illumated rocker switch that came with the set, but after a switch like the one on the hood that turns that light on. That way when the box is opened the switch will light up. I can either set it to turn on when I flip the switch or be on when I open the box.
I can't count the times I wish I would have had something like this while I am camping, working, etc.
Also, I plan on mounting an air compressor back there. This will be a great summer for rafting!!!
Wahoo!
Old Aug 26, 2005 | 07:41 PM
  #39
KP SCAB's Avatar
How's everyone been doing with their bedlights? any photos. I am interested now that my bedrug and cover are on the way. I want to see who's idea worked best. rope light vs. closet light vs. cold cathode vs. fog light vs. server indicator light.... and who's wiring solution worked out the best.
thanks
