How to Fix a Defective Window Switch
Old Jan 18, 2012 | 04:31 PM
  #121
FX4'05's Avatar
Fixed my DS and PS window last night. Good pictures and steps to follow made it very easy. Thanks
Old Feb 19, 2012 | 08:02 PM
  #122
BOHTR's Avatar
Fixed my passenger side switch yesterday !! Thanks for a great write up !
Old Mar 8, 2012 | 09:12 AM
  #123
kstrob's Avatar
Thanks bud...fixed my driver side in less than 30 minutes. Good pics
Old Mar 8, 2012 | 12:23 PM
  #124
jimcam22's Avatar
Thanks for the write up. I used my old brake adjustment tool to lift the switch panel off.
Old Mar 16, 2012 | 04:09 PM
  #125
Chucho's Avatar
Window Switch
Thank you for the pictures & directions! I fixed my driver side window just by cleaning the contacts. I did however bust the small clip holding the window lock switch cap, I thought it would pop off like the window ones. I was able to salvage it with some black tape and it works fine. So just be careful with that one.
Old Mar 25, 2012 | 08:50 PM
  #126
Rhynko's Avatar
My truck has had this problem since I purchased it 3 years ago with the driver window switch having to be wiggled back and forth to bring the window up. 10 minutes and it was working like a brand new window. I also found that the pin in the switch that controlled my automatic down on the driver window was broken. I was able to switch it with the "down pin" and now it works again. I can't control the amount the window goes down anymore it will only go completely down on its own, but I'm ok with that for now only takes 10 minutes to change it if I ever get tired of it.
Old May 12, 2012 | 03:07 PM
  #127
F451's Avatar
Add another to the "Did the window switch fix" list.
Thanks for taking the time to document this, its a huge help! -Ed
Old May 20, 2012 | 10:17 PM
  #128
dixie_boysles's Avatar
Just saved me some monies!!!!
Old Jun 2, 2012 | 11:27 PM
  #129
IROC it's Avatar
Perfect walk through... Works like a charm!
Old Jun 21, 2012 | 03:58 AM
  #130
NoChainz's Avatar
From: The land of Big Trucks and Guns! Yeeehaw!! ;)
Both windows are going out. I'm doing this tomorrow!!!! Thanks!!!
Old Jul 7, 2012 | 06:33 PM
  #131
DavEnzoF1's Avatar
I owe you a beer!
I'm not mechanically talented, but from reading your posting TO fixing the window TO bragging that I fixed it TO now has only been an hour. Thanks and Good Karma to you.
Originally Posted by mblouir
Note: I did this for my 2007 Ford F-150, but it should be nearly identical in terms of process for other vehicles.
Background:
A few months ago my passenger side window switch became defective. It was capable of rolling down the window, but was not able to roll it back up. I had to do it from the driver's side. I could still completely control the window from the driver's side, though, so I knew it was an issue with the switch. It's been a busy semester, so I had decided to put off looking into it until summer.
Well, today I was taking the dog to the park so I had my windows down, enjoying the day. When I got to the park, my driver's side window would not roll up. Same issue as the passenger's side; it would roll down but not back up. It took some playing with to get it to roll back up. In other words, I sat there for five minutes flipping the switch until it went back up. It is supposed to rain tomorrow, so I decided to leave it go until I had more time to look at it.
Sooooo that didn't work out so well. Being the intuitive mind that I am, I decided to check them out. The driver's side costs ~$70 to replace from Amazon, and the passenger's side costs $40, also from Amazon. I don't have $110 laying around to spend on window switches, so I wanted to try it myself. I did in fact figure out what was wrong, and fixed it. The cause of the issue was bad contact points. This is usually the case in terms of window switches becoming defective. All you need to fix this is maybe one or two small screwdrivers, and something to wipe off the contact points with (I used Cu Tips). This is a short tutorial of how to repair defective window switches with this issue.
First Step: Remove Window Switch
This step will vary based on your vehicle. You should be able to pry up a section of door panel to gain access. Just unhook any connectors necessary and use a small screwdriver to pry apart any snap-fits. You only want to be dealing with the switch board itself.
2nd Step: Gaining Access to Switch Internals
The caps over each switch (your window buttons with up and down arrows) will pry off easily. After those are off, remove the actual switches (white pieces for my truck). These were also snap-fits, so use one of the small screwdrivers to pry them out. Now remove the small metal tabs underneath. These were simply laying in position, so flipping the whole configuration over will allow them to fall out.
3rd Step: Diagnose your Situation
You may or may not have bad contacts. You will know immediately. If not it is something else, so do a little research and see what you need to do. If you are at this point you obviously wanted to try a DIY fix before paying over a hundred bucks for new switches. It's worth trying to fix while it's apart. If it doesn't work, you're out nothing and you have to buy new switches anyway. Worth a shot, right? Here is a look at a good vs bad contact.
Last Step: Fix it!
It's quite obvious the problem here was bad contacts. All I did was scrape off the crud and afterward wiped the contacts off. Use whatever tool can get the job done. If at all possible make the contact points as smooth as possible for a clean connection.
Just do everything in reverse to put it all back together and go test it. For me, it worked for both the driver and passenger sides! Good luck. This is a fairly straightforward fix if you're comfortable doing this. I had to take new pictures since I lost the old ones, and this whole process took me less than 10 minutes.
-Matt
Old Jul 28, 2012 | 09:30 PM
  #132
ColoMtnGuy's Avatar
Background:
Last Step: Fix it!
-Matt
Great write up, had this problem, fixed in less than ten minutes. The photos were great. FYI, you can use the eraser on the end of a pencil to clean up the contacts. Just put the end on the contact, swirl it around and it'll clean it quick. If it's really bad, I took some 800 grit wet/dry emery paper and cut a couple of strips about 1/4" wide, 5 inches long and drew them over the contacts. BTW, do not use WD40 to clean the contacts. It can leave a residue on them that will cause arcing. You're better off not putting anything on the contacts overall. Contact cleaner is okay, but some has an oil in it...
Old Aug 22, 2012 | 12:15 PM
  #133
manycars's Avatar
Thank you
Okay, so I am lazy. I just bought the new switch and installed. Took about 5 minutes with you great instructions. Save me $200. Thanks!
Old Sep 9, 2012 | 02:22 PM
  #134
M125X's Avatar
Just fixed mine! Thanks!!
Old Oct 1, 2012 | 08:40 AM
  #135
Foo52's Avatar
Thumbs up
Thank you so much!!! Nothing really captures the essence of a Monday morning then your driver's side window being fully open when it's 45 degrees out and no way to put it back up!
My diagnosis found that in addition to excess corrosion on the contacts (had noticed it was arcing a lot when I had taken the casing off and tried to open/close the window), I found that the springs had worn at an angle. So just to play it safe I swapped the springs and up pin with one of the rear window's one and it works like brand new, the old ones now in the back even seem to work. Saved me a lot of time, money, and headache!!
