PRND21 pointer fix
Old Nov 9, 2009 | 12:48 AM
  #31
no_pistons7's Avatar
awsome! i know what im doing tomorrow
Old Nov 12, 2009 | 07:56 PM
  #32
RJP66F100's Avatar
Originally Posted by willys5555
this would be a great help to me as sometimes when i get in the truck it wont start until i bump the gear shift so it points in the right spot. there has to be an adjustment somewhere...right? lol
Adjusting the indicator will not help your starting problem.
Your linkage down at the transmission might need adjusted though.
Old Nov 12, 2009 | 08:35 PM
  #33
willys5555's Avatar
but when i move the shifer up, it lets me start it... or is it not the same?
Old Nov 12, 2009 | 09:44 PM
  #34
edgespeeder06's Avatar
Well thats the problem I have. I have 3 inch left and sometimes mine won't start unless i pop it into neutral or back into park......how do I fix that?
Old Nov 14, 2009 | 01:45 PM
  #35
06yz250f's Avatar
found out the other day, its pretty much the same location on a ranger. the trick tho is you have to reach your hand up the dash into a tight spot, so if you have big hands you might need someone with smaller hands.
i was working on an 01 ranger, so not sure on other years.
Old Nov 15, 2009 | 02:04 AM
  #36
UnbridledFury's Avatar
Awesome tip! I just did it (almost 11:00 PM) - it took a minute to get it adjusted correctly. You do have to be a bit of a contortionist to get to it, though.
Old Nov 15, 2009 | 02:53 PM
  #37
flbuilder1's Avatar
Can't seem to find it on my 2000 supercab. Followed it from firewall up no adjusting screw. Been driving me nuts for 2 years. Any other places to adjust?
Old Nov 15, 2009 | 03:45 PM
  #38
flbuilder1's Avatar
Cannot seem to find mine. Have 2000 supercab. Traced cable back from firewall to steering column. Doesn't seem to have adjusting wheel just a support. Been driving me nuts for years. Any other suggestions? Thanks for your help.
Old Nov 15, 2009 | 04:02 PM
  #39
Raptor05121's Avatar
Originally Posted by dirtyd88
Never knew this. Thanks Patrick.
haha silly automatics.
Old Nov 16, 2009 | 02:55 PM
  #40
dang everyone is having trouble finding it i might have to do a quick video
Old Nov 16, 2009 | 05:36 PM
  #41
it has to be in a different place on my 04 new body style f150 or im blind lol
Old Nov 17, 2009 | 03:36 PM
  #42
fiveohpoepoe's Avatar
Originally Posted by AZTriton
yeah, mine was way off and I just found out that white bracket that holds the adjuster in place broke. The rest of it is very brittle; piece of garbage. $35 to replace? Jeeeeeez.
Only place to find the brackets? My top piece is broke. Do you have a part number or something I can reference?
Also, its there guys. Id assume all of the 97-03[F150s] and 97-02 Expys have it in the same place. Takes a little eye searching, but its there
Old Nov 17, 2009 | 09:03 PM
  #43
BlackFord123's Avatar
thaqt would be absolutely wonderful because i feel like an idiot cuz ive been looking for literally a week lol jus throw up a quick video showin where it is and that would be awesome thanks pat
Old Nov 18, 2009 | 12:03 PM
  #44
flbuilder1's Avatar
Thanks patman. I finally did find it won't need a video. For anyone who can't find it it is on the bottom of the steering column up under the dash. I had to get my head almost to the fire wall and look towards the steering wheel to see it. Also it is not real big.My white peice is broke so I assume i cannot adjust it. Can that piece be replaced or does anyone have another fix. Thanks
Old Nov 18, 2009 | 12:10 PM
  #45
Correct, you cannot adjust it with the broken tab. My top piece is broken and it looks like you have to buy the complete piece...Im trying to find the part number or info where to buy instead of Ford
