PRND21 pointer fix
Old Nov 3, 2009 | 09:41 PM
fiveohpoepoe's Avatar
Great info. Ill be trying it very soon. Thanks for the post
Old Nov 3, 2009 | 10:53 PM
willys5555's Avatar
I still cant find mine...would the 97 really be different?
Old Nov 3, 2009 | 11:06 PM
possibly, i havent been under a 97 dash myself. Ill try and get Paul to take a look under his truck soon to find out for sure.
Its up there pretty far, basically forward of where your knees are when seated in the turck
Old Nov 3, 2009 | 11:43 PM
willys5555's Avatar
ok thanks. that would be great. i followed the wire all under there from where it goes out of the cab up to where it connects up by the cluster.
Old Nov 4, 2009 | 12:38 AM
AZTriton's Avatar
yeah, mine was way off and I just found out that white bracket that holds the adjuster in place broke. The rest of it is very brittle; piece of garbage. $35 to replace? Jeeeeeez. That's almost as bad as $25 for a pack of 10 o-rings for the fuel injectors I was robbed for at the Ford Stealership.
Old Nov 4, 2009 | 07:59 PM
BlackFord123's Avatar
I have the same problem... I was looking for it and cant find it i have a 98
Old Nov 5, 2009 | 11:36 AM
nonwoven29's Avatar
Worked perfect and I also found the 2 torxs screws where almost backed all the way out after tighting them up i was able to adjust the selector thanks you. The screws where a big part as well there no slop in my selectore now thanks for the info pat.
Old Nov 6, 2009 | 01:19 AM
1BAF150's Avatar
Originally Posted by b2therad
Nice! Mine is broken for sure I think.. My park is actually pointing to the R. It broke out of no where one day when I shifted into park.. it just would not go all the way. It goes through all the gears fine but its just one over on all of them.. weird I know.
Haha, didnt know other people had a problem with this on here. Yea, mines the same way..just broke out of now where one day when I put it in park. Been like that since..guess I'll have to try it now! Thanks Patman!
Old Nov 7, 2009 | 05:50 PM
Danieldd's Avatar
It is there, keep looking. I have a 98 and I just adjusted mine. Can't believe I've been driving around for the past 2 years with it between D and 2. Now its spot on!
Thanks for this invaluable tip!
Old Nov 7, 2009 | 07:03 PM
bro I havent been able to find it at all..... from a 98 owner to another can you give me a pic or a good description of where you found urs at? thanks!
Old Nov 7, 2009 | 08:49 PM
MudTerrain's Avatar
Good info.
Old Nov 8, 2009 | 11:57 AM
BigBadFord_eric's Avatar
Talking
Are you tired of seeing your pointer in the wrong place, here's a quick fix for you
[IMG]
Look under the dash at the lower side of the steering column and you see this black adjuster
[IMG]
[IMG]
Pinch it and spin it until the pointer is in the correct place
[IMG]
ive always wanted to fix this little problem but i never knew how
thanks for the tip man
Old Nov 8, 2009 | 12:10 PM
01crew4x4's Avatar
Thanks for the info. Mine's been off for over a year now and I always wonder how to adjust it. Just did it Friday worked great.
Old Nov 8, 2009 | 05:14 PM
willys5555's Avatar
well being i cant find mine...there has to be another way of adjusting it right? maybe just in a different spot? this would be a great help to me as sometimes when i get in the truck it wont start until i bump the gear shift so it points in the right spot. there has to be an adjustment somewhere...right? lol
Old Nov 8, 2009 | 06:56 PM
edgespeeder06's Avatar
Hey any idea where it is on a 2004+ F150? I haven't spotted it yet but mine is very off too.
