Niteshaded LED Taillights (High Gloss Shine 56K NO)
  #46
Old 07-01-2010, 02:12 AM
BigTruckGuy's Avatar
Great How-To!! Thank you Im going to tackle this tmrw hopefully.
I read this then searched youtube and found 2 videos very similar to this thread. it helped alot also. watching and reading instructions is very helpful. Heres the videos...
http://www.youtube.com/watch?v=OSKA0...eature=related
http://www.youtube.com/watch?v=-8-hZ...eature=related
  #47
Old 07-02-2010, 08:33 PM
Help!! I just got done puttin my second coat on and went to put on my 3rd coat and it was sprinkling rain outside. i picked the lights up and brought em inside.
Do i wipe off the water or let it sit???
  #48
Old 07-02-2010, 11:56 PM
i fixed it. i dabbed it with a towel and it left specs but they came out with the 3m compund.
but i just used 3m compound and didnt use the PLastX or Crystal Shine thinking that would be enough to make it shine but its not they are still to foggy so i have to go get some tmrw and put on to shine them up.
So just a heads up for future users: follow all steps and dont skip any. Use all polish compounds to get real shine!!
  #49
Old 07-03-2010, 11:21 AM
05BlackFX4's Avatar
The plast X really is what brings them to life....glad they are working out for you...I forgot this thread was in the how to section....ooops
  #50
Old 07-03-2010, 11:23 AM
05BlackFX4's Avatar
Originally Posted by Bshipe22
can you do your headlights the same way?
yes you can...and fog lights....just remember to keep temps above 70 degrees or you can have curing/bonding issues with the paint and achieving the glossy shine.
if anyone has questions on these PM me and I will answer...usually on every couple days and haven't checked this thread in awhile.
  #51
Old 07-03-2010, 06:31 PM
Heres my finished product. very happy with the results!
Before
After
Now onto the 3rd brake light
  #52
Old 07-03-2010, 10:47 PM
just in case i mess up on my bros what can i use to get all of what i had on it off and start over??
  #53
Old 07-05-2010, 04:49 AM
05BlackFX4's Avatar
^^Just wetsand with 600 grit sand paper and the paint will come off...then start over
Very nice Big, looks great
  #54
Old 07-05-2010, 01:02 PM
Thanks man.
And Thanks i like it alot better then the red.
  #55
Old 07-06-2010, 01:50 AM
and heres the brake light....
0
well as you will see in the next pic i went out today after gettin the 3rd brake light dun. installed it and looked everything over and my tail lights have like a whitish tint to them..kind of like their not very clear in some places..like a fog..(u can see what im talkin about in the pic) so i took some more plast x to them to try and work it out but it didnt....
i think the reason is is because all of the buffing and polishin i did by hand and not by a machined buffer...
so should i redo them all over again or what???
  #56
Old 07-06-2010, 04:08 AM
05BlackFX4's Avatar
wetsand them with 1000 or even 2000 grit to scuff....then re-clear them and do the polishing over again if you would like. The new layer of clear should put a new finish on the outside of the lens and fix your problem.
Machine buffers you can get at schucks, oreilly's etc..they are about $20 bucks
  #57
Old 07-06-2010, 05:11 AM
ok il try that. thanks man.
did u get what i was talkin about? how it has that white look around the edge...
  #58
Old 07-06-2010, 07:06 PM
05BlackFX4's Avatar
yea it looks like it might be excess clear coat
  #59
Old 07-06-2010, 10:55 PM
ok. so what about if i get them to dark and wana lighten em up? sand 600 then clear coat and polish??
  #60
Old 07-13-2010, 06:53 PM
FXFordriver's Avatar
Ugh! I was doing my third brakelight and went to put the clear on and it came out a murky white. I'm guessing I got a bad can or something. Now the whole thing is totally jacked! I tried sanding it down and starting over, even with 250 grit. It's too messed up. I guess I'll be buying a new one.
Quick Reply: Niteshaded LED Taillights (High Gloss Shine 56K NO)
