The Official LT handle install guide (w/pics)
Old Apr 5, 2006 | 11:33 PM
roushlimited's Avatar
Originally Posted by RockPick
I just wanted to chime in to tell you that this is one of the best 'how-to articles' that I've seen posted here... there are lots of good ones but, this is way up the list...
Guys -- this is why the REPUTATION point thing is here... for those of you who really think that he went out of his way to help out with this article, send out some rep points his way... to do this, look for the little scale and choose approve!
RP
Hey RP thanks for the kind words. Just hope it helps people out.
Old Apr 5, 2006 | 11:36 PM
keith61760's Avatar
This is AWESOME!!! This is exactly what I was going to look for when I finally order and do mine Thanks Roush!!
Old Apr 6, 2006 | 02:13 AM
You're very welcome
Old Apr 6, 2006 | 02:29 AM
Josiah's Avatar
Originally Posted by roushlimited
I know... I actually did this mod like 3 weeks ago but I could here a little nut that I had dropped and thought had fallen onto the ground inside the door panel. Josiah had asked for a write up on it so considering he helps us all out with his write-ups and videos, I though it only fair to help him out. Those speakers suck and believe me they will be replaced soon.
How nice of you to go out of your way for little ol me. Thanks a lot, I guess I'm now required to buy those suckers since I made you post this. I needed a little pressure anyway, but give me a week or two so I can stop feeling like I'm at a huge financial loss (lift).
I just purchased pillar mounted spotlights from Unity, I'll post the installation of those (going to be scary as chit...it's going to be like putting 3 holes into my chest...gonna close my eyes ).
Thanks again, very nice writeup...best writeup on these LT handle installs I've seen yet.
Old Apr 6, 2006 | 03:55 AM
Nates06SCab's Avatar
I could do better, but I probably won't . I did it a bit different, but excellent job!!! I wish it'd been there for me when I did mine.
Old Apr 6, 2006 | 01:23 PM
(quote)I just purchased pillar mounted spotlights from Unity, I'll post the installation of those (going to be scary as chit...it's going to be like putting 3 holes into my chest...gonna close my eyes ).(quote)
That'll be sweet I assume you ordered the black ones to match your truck. Good luck I know I couldn't cut my door pillar.
Old Apr 6, 2006 | 03:13 PM
cvc14's Avatar
Great write up
Old Apr 6, 2006 | 05:21 PM
teknics's Avatar
Great write up. I did things a little differently also.
For the lock cylinder, when the door handle is removed from the door but still connected to the rods, remove the retainer clip from the lock cylinder and pull it out. Twist it off and set it aside.
The hardest part was getting the plastic clips off for the wiring harness.
Taping the door is another important step.
Old Apr 6, 2006 | 07:40 PM
Josiah's Avatar
I ordered the black ones at first, then canceled my order for the chrome ones, I now am starting to regret that, lol. I would cancel it yet again and order the black ones if I could...but I can't.
Old Apr 7, 2006 | 09:19 AM
TCC-'s Avatar
Very good!! I will be installing same painted xlt handles this weekend !!!!
Old Apr 7, 2006 | 09:21 AM
speedwolf's Avatar
Thanks for the write-up. My handles will be here next week, so I'll be installing them next weekend. This should make things a little easier.
Old Apr 7, 2006 | 10:20 AM
Tical84's Avatar
Good job! I like pictures .
This is good enough to be in the "Technical Articles" section.
I'd bookmark it but I'm at work so I'm posting to make it easier to find when I get my handles.
I actually eliminated the keyholes and keypad
What happens if your keyfob runs out of batteries?
Old Apr 7, 2006 | 02:53 PM
Pretty much the same thing as guys with shaved handles run out of batteries. SLIMJIM If that happens I'll use my Ford Roadside Assistance and have them open it. Paid for it might as well use it. I'm toying around with a few other ideas too right now but haven't decided yet.
Old Apr 7, 2006 | 07:15 PM
BADnBLUE's Avatar
Anyone have part numbers?
Old Apr 7, 2006 | 07:50 PM
HotLap's Avatar
Nice write up and the only things I would add from my installation of the LT handles is:
1) Be sure the rods (that attach to each handle) don't get turned 180 deg - they will still reinstall - but after door panel reinstallation - the handle "action" will bind....then you get to completely disassemble and reassemble again ....I know this from 1st hand experience!!
2) You can completly remove and set aside (rather than leave hanging) the door panel by disconnecting the cable that runs down inside the door to the lock....disconnect at the rear of the inside door handle.
3) Duct tape around the lower edge of the outside door handles - you will be turning/twisiting the handle buckets to get them off the rods and it is easy to scratch the paint.
4) If you want to be "****" like I was with my installation and have the two door jam screws (just like the originals)...you can remove one of the door jam screw "buckets" from the old handles once you have removed it from the door....just start backing out with the tap of a chisel and then use pliers.....to install into the new handles simply install the screw and use a ratchet to bottom out in the correct hole.
5) Be sure to have Dynamat Extreme / TAC mat handy and replacement speakers so you can get it all done at once!
By the time you get to the 4th handle - you're going to be a pro
