DIY Intake Modification for 1997-2003 F-150
Old Apr 6, 2015 | 11:34 PM
  #256
Veteran: Army
Originally Posted by Fordman450
I put a spectre universal intake in my 03 f150. Forgot to unhook my battery and it wouldn't run. Then I was told to unhook my battery and let the computer reset I left it unhooked for about a minute or two then hooked it back up and it still won't stay running. Any advice?
return that garbage
do the gotts mod
Old Mar 25, 2016 | 12:27 AM
  #257
Lago_F150's Avatar
I am attempting to do this mod now finally. Truck is a 2000 F150 XLT 5.4L 4x4. I bought it used many years ago and it already had the K&N kit on it. I never liked how it sucks the heat from the engine compartment. Living in Arizona I notice a performance difference during the summer. Also I don't think it filters as good as they say, but that's another topic. Since I did not have the stock intake, I bought one off of eBay from what I thought was another 2000 F150 5.4L. What I got was the intake from a 1997. My question is does anyone happen to remember the inside diameter measurement of the filter housing after removing the snorkel? These different years appear to have different size openings.
This is what I received which looks like what I've also seen in pictures of the V6. As you can see the snorkel connects on the outside of the housing.
Based on pictures from others performing this mod, this is what I should have.
This piece snaps into the inside opening of the housing.
My concern is that the opening on the one I received which I measured to have an inside diameter of 2 5/8":
and the opening on this:
do not have the same inside diameter. If I go with the one I received I would be choking the engine. What tipped me off was when you connect the 3 inch rubber coupler to the housing and PVC pipe that goes into the fender, there is a good 1/4" to 3/8" gap all the way around to seal off on the filter side and is just way too loose in my opinion to use. The VIN number this intake came off of was on the receipt. It shows it's from a 1997 V8, 1FTEX18L3VKC57705. Maybe the difference is due to when Ford went to the PI heads? Thanks for any help you can provide.
Old Jul 9, 2020 | 09:35 PM
  #258
brady 01f150xlt's Avatar
did this mod for 20$ I am currently installing it now only gona be a 10 min job.. I also pulled the silencer out in the big L piece can’t wait to put it back together and see if it did anything
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Ch1ro420
65. Biggoldie
66. samirar
67. FlashmasterK
68. Rojo024
69. MikeChris2
70. buxton91
71. DMD09
72. willys5555
73. 428GT
74. Dinggus
75. kieth 2000 xlt
76. Alexcngford
77. XtremeBawls
78. AZ98F150
79. sean46
80. russ10screw
81. 2Low2Go
82. BigTruckGuy
83. Red02FX4
84. nhford
85. FX41
86. Dukes218
87. Poolboy1191
88. KingranchCoy
89. enriched
90. BOMO
91. Wildcatt
92. CGpinoy
93. Tommer
94. rdicarlo
95.Wolff-SATX
96. Trucky911
97. jdub96
98. Blue02FX4
99. islandfordguy
100. TJA349
101. Spyawn
102. BLUE20004X4
103. OVER_KILL
104. PapaBare
105. SFCFX4
106. bogeyrider63
107. dumontdude10
108. LonestarROB
109. low bass
110. Jared Lutes
111. Pockets
112. recountry2
113. Hiwire
114. BLFX4K
115. vaipunk
116. Jaxson
117. Motox852
118. eghead
119. ScrewedUPF150
120. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
104. Moosenuckle
105. Barrett
106. lenmore
107. MUDDUCK7
108. DarkShadowStx
109. 06f150stx
110. Medicf150
111. raggidy tom
112. Slick Whitman
113. Hanginten24
114. Hardrock3742
115. Rctaylor17
116. REBEL 4X4
117. Socalkid3
118. OptimusPrimeFX4
119. Chexfam
120. Mikesea
121. FoMoCo905
122. Fordordie1
123. 1997 lariat 4.6
124. Fordfan4life199
125. Mad Texan
126. Buck 119fa
127. AndersonS
128. Ace_boy2099 (and ZooDad Mod on SuperDuty)
129. Animated Zombie
130. olscout99
131. 2000xltguy
132. Oblivion
133. SubSkip
134. czar1998
135. Retto4
136. Aldo Galarza
137. twlightning -01 SCREW 5.4
138. j0nathan88
139. brady 01f150xlt
Old Jul 9, 2020 | 09:58 PM
  #259
They maintain a list of those doing the modification.
Old Jul 22, 2021 | 02:55 PM
  #260
Acherom's Avatar
Did the mod.
2002 f150 4x4, 4.2l, 5 spd manual tranny
my truck came with the smaller end on the filter cone so I cut the cone further up before attaching the rubber. Still not as big as the other fitler cone type (I'll buy one later) but opened it up some. Sounds a touch better but primarily gives me better high end rev at highway speed. We'll see how it goes. lol
Old Oct 6, 2021 | 08:26 PM
  #261
Constructionman's Avatar
Did gotts mod like results used angle grinder with cutting wheel to cut down flange O
Originally Posted by stoffer
Do you feel your truck needs more air?
Are you not willing to pay $250 or more for a “cold” air intake for your ‘97-‘03 F-150?
Are you afraid of “cold air” intakes sucking in too much hot air from your engine bay?
Do you think drilling or cutting up your factory air filter assembly looks too tacky?
Are you afraid of permanent modifications to your truck?
Do you already have an aftermarket drop in filter?
Do you want to keep running paper filters?
Do you prefer the look of your factory intake?
If you answered YES to any of the questions above; then look no farther than this simple easy modification to your factory intake that will be 100% reversible at anytime if you are ever unhappy with the results.
NOTE: Something to Consider: at the time this was written up Troyer Performance (TP a great source in F-150 performance and custom tuning) has data logged and has dyno tested all of the aftermarket intakes available for the F150 and has thoroughly documented the results. TP has found that the stock intake runs the second coolest only beaten by the Airforce-1 which TP lists for $239 on thier website. With this modification you are getting a lot colder air into your engine than most of the aftermarket intake kits on the market today. It could potentially be colder as well but we wont know for certain until someone data logs the IAT with both intakes.
Tools and items needed to complete this modification:
1 - Straight screwdriver
2 - Sander, dremel tool, file, grinder or some kind of sanding device
3 - A 3-inch pipe flexible coupling (preferably black) inside diameter will be around 3 ˝ inches to accommodate the outside diameter of the PCV pipe.
4 - a 3 inch diameter PCV pipe (black is preferred but color doesn’t really matter)
5 - 2 hose clamps (the pipe coupler should come with 2)
6 - 8mm wrench or socket
* Now you are ready to begin. First things first go lift your hood and look where your factory inlet tube meets your drivers’ side fender. Yes this tube right here:
This is the cause of your trucks lack of performance at higher RPMs because this factory piece is literally choking your truck. Look at the tape measure and see for yourself.
As you can see this is why the factory piece has less than a 2-inch diameter inlet tube and you are about to give your truck a true 3-inch diameter inlet tube that doesn’t suck in hot air from the engine compartment. This intake modification still draws in ambient air temperature thru the fender well just like the factory designed.
1. Start by disconnecting your negative battery cable (to reset your computers strategy for the extra air coming soon from the modified intake) needs a 8mm wrench or socket.
2. Undo this clamp right here with a straight screwdriver:
Remove your entire air filter housing assembly (the large “bucket” where you change air filter all the way to the fender snorkel. (The snorkel will just pull out of the inlet hole)
*On my truck the Previous Owner has bent the metal clasp so I had to remove the entire assembly as I have to have the whole housing out of the truck in order to close it properly*
OR
Just take your air box apart like you are changing air filters and just remove the piece that goes into the fender
3. Use a straight screw driver to undo the snorkel cone:
There are 2 points inside the tube just press the ends with a screwdriver and they release
4. Cut off a 4-5 inch section of pipe:
Originally Posted by cH1rO420
Thanks Terajame I was waiting for something like this with more pics. Will do this soon.
So all I need is a flexible coupler, 3 inch and those 2 straps that tighten with screw?
I have 3" pipes around here so I won't need to be buying any.
