Buffer Question
Old Mar 5, 2002 | 08:56 PM
MASVT's Avatar
Buffer Question
what's the difference between an orbital and rotart
buffer. and what's the best one to use I want to
get my paint looking good for spring
Old Mar 5, 2002 | 09:03 PM
Chikenears's Avatar
An orbital buffer spins and wobbles on its axis at the same time. A rotary buffer just spins. I would suggest the orbital if you're not experienced with high speed buffers.
Old Mar 5, 2002 | 09:14 PM
MASVT's Avatar
What is the best for using3m swirl remover
I want to remove some swirl marks and I heard
3m is the best is an orbital good for using that
product, when removing the wax should I use
foam pads or should I use terry cloths
Old Mar 5, 2002 | 09:19 PM
Chikenears's Avatar
The orbital is for you. A rotary buffer, in general, creates swirl marks. For removing wax use soft cotton cloth.
Old Mar 5, 2002 | 09:20 PM
Masterloggie's Avatar
Cyclo is the best brand name buffer for the regular ammuter to remove swril marks. EXPENSIVE.
Ron
Old Mar 5, 2002 | 09:27 PM
Chikenears's Avatar
I totally agree with Masterloggie
http://www.properautocare.com/cy-pol.html
Old Mar 5, 2002 | 09:40 PM
Chikenears's Avatar
Porter Cable makes a nice polisher too if the Cyclo is out of your price range. The Porter Cable does a good job too. Not too pricey.
Old Mar 5, 2002 | 10:13 PM
Jay Lincoln's Avatar
I've got Porter Cable, and use Griot's #2 polish. I works for me!
On a daily driver like mine, you need the more agressive polish. their #3 polish is too fine.
FireGuy's Avatar
Griots garage has all the info on buffing
http://www.griotsgarage.com/index.jsp
Old Mar 5, 2002 | 11:21 PM
99 SVT Bolt's Avatar
Old Mar 7, 2002 | 11:40 PM
mr2x75's Avatar
Ive got a makita varible speed buffer, and use 3m perfectant compound and glaze , I buff alot and it has held up well my wifes dad has a small body shop . and i do all his finish work, most of the better clears i use only a foam pad, and just switch compounds, some clears get so hard you have to start with a wool pad, then foam. if you have the experience you will have no problem using a foam pad and glaze to get swirls out, I get them out of black all the time. start with 1200 or 1500 grit wet sand paper then go to 2000 then 3m perfectant compound then finish out with a foam pad and 3m perfectant glaze. then a good carnuba wax. oh almost forgot I keep a mist bottle of water with a little bit of car soap to keep friction down when im compounding, watch your edges, keep it movin, if your new go to a body shop and get a old door trunklid etc and practice. My 2cents is that orbitals are only good for wax.
Dale {mr2x75}
