Nitto trail grapplers
Old Sep 14, 2014 | 08:52 PM
F150Freak24's Avatar
Looking to buy nitto trail grapplers 285/70-17 on a stock 2014 ecoboost. The rims I want are 17x9 with a 0mm offset that should fit with those tires if I have a stock truck right just wanna make sure before I make a 1600$ mistake I looked on the forums to find my answer but can't get exactly what I'm looking for.
Old Sep 14, 2014 | 09:44 PM
4x4 or 2WD? If 4x4, you should be alright, but I'd expect to have to trim a little. If 2WD, you'd have to add a leveling kit to fit those.
Old Sep 14, 2014 | 09:53 PM
It's a 4x4 and they also have +25mm offset for the ballistic wizard rims if that works better
Old Sep 14, 2014 | 10:02 PM
Those Ballistics would potentially fit better, but I'd just get what you want. The 0 offset will stick out more, whereas the +25 would be closer to stock. The tires are only 1" taller than the stock 275/55/20s that come on all the ones with 20" wheels, and are only a little wider, so should be fine even with those 0 offset ones.
Old Sep 14, 2014 | 10:25 PM
So does the 0mm offset mean I will have more clearance with the tires to prevent rubbing or will a +25mm work better I would really like to not have to trim or level it if i have to I'll just add a level kit I just don't want it to possibly void my warranty for putting in a level kit.
Old Sep 14, 2014 | 10:31 PM
Offset, when the width of the wheels you're comparing is the same, indicates the amount of backspacing. Backspacing, essentially, translates to how far the wheels stick out. You can Google for images that explain this if it's confusing and you care to learn more. 0 offset is an "offroad" style wheel that will poke out a little bit.
Trimming won't void any sort of warranty and it's just about impossible to see that any trimming of the plastic valance has been done unless you stick your head in the wheel well and look. For a leveling kit, the only warranty that can be voided by that is ball joints and potentially CV joints. However, if you were to add a 1" or 1.5" level, the additional stress on those components would be very minimal.
But again, you should be perfectly fine with that set up. Trimming is easy, quick, and not noticeable, and I'm confident that that is all you would have to do to fit those 17x9 0 offset wheels and tires. And you may not even have to trim at all.
Old Sep 14, 2014 | 10:44 PM
Thanks a lot what kind of rims and tires are you running id like to see some pics if you've got some
Old Sep 14, 2014 | 11:41 PM
No problem! It's unnerving trying to find out what'll fit.
I had 20x8.5 +18 Eagle Alloy wheels with 275/60/20 (33.0x10.8") BFG Rugged Terrains on my leveled (2" added front and back) 2WD before. So that sat right about how yours would. Now I have 20x10 -24 Fuel Mavericks with 35x12.5x20 Trail Grapplers. That first set of wheels and tires would be pretty darn similar to how yours with be with the +25's. But yours would poke out just a little more because the Trail Grapplers are wide.
Here are a bunch of pictures of both:
https://www.f150online.com/forums/me...94-albums.html
Old Sep 15, 2014 | 12:02 AM
Out of all my research I think I'm going to go with 285/70-17 trail grapplers (which will kill my mileage probably) on ultra baron 17x9 rims +25mm offset and I hope I don't have to trim just because I'd rather not if anyone thinks I might have to trim or level it tell me what might be better to minimize all that thanks!
Old Sep 15, 2014 | 01:27 PM
I don't think you'll have any issues at all with that setup. Trimming is no problem at all either, like a complete non-issue in my opinion. But obviously it's better/easier to not need to trim.
