Build!!! 09-13 front end conversion project on an 05 screw!!!!!
Old Oct 10, 2014 | 11:29 AM
Originally Posted by coobies5
hope you get the frame straightened.......that front end is beyond gone.
Yeah, is the frame able to be straightened?
Bad A though! Got part numbers for hood hinges, or were they OEM? It'd be cool to make a write-up on how to do this so others can follow suit.
Old Oct 10, 2014 | 02:50 PM
jsosa13's Avatar
got oem hinges for an 09 and up off ebay. all that missing to buyer in the front end is the fx4 2 bar grille, trying to wait and get a deal most about between $260-280
got the ends straightened with another truck and chain took about 15 minutes, it was from the condenser forward. there not perfect yet, im waiting to get ready to mount bumper to make adjustments accordingly
once im done with the assembly ill make a write up for exactly how to do the front end conversion. bumper will be the hardest part of the whole thing everything else pretty much bolts up with minimal work.
Old Oct 10, 2014 | 07:04 PM
I'd be concerned with the wallop those frame horns took having been sent to the rest of the frame, but hopefully not. Hope to see this all buttoned up and driving properly!
If I recall from Raptor conversion threads, 2" or so needs to be cut off the frame horn ends, so I agree that it sounds like the suckiest part of all this. I love that the panels and hood essentially just need mount location mods.
Old Oct 10, 2014 | 08:08 PM
jsosa13's Avatar
had some more time on my hands today. took care of tightening the bed down, adding the tailgate, and start on the bumper.
Old Oct 10, 2014 | 08:12 PM
jsosa13's Avatar
I had been going back and forth on whether i needed to trim back or not thanks
quick question in order to level the turkc i would need about a 2.5 lift right? also in the picture i posted of one completely done on the first page are those xd rockstars 20's? it should turn out just like that one but with 09 mirrors, and 2bar grille. any other style you recommend on wheels??
Old Oct 11, 2014 | 01:46 PM
No problem, hopefully that helps!
You'll have to measure the gap difference from front to back, just because every truck is different, leaf springs start to sag, etc. I like adding 2 to 2.5" in the front and then adding a block (if 2WD) or bigger block to the back (if 4x4) so the whole truck gets lifted. That's what I did. Autospring is great, and inexpensive, company to get both from.
Yeah, those are 20" Rockstars on 37" (or so) Mud Grapplers. I have Fuel Mavericks, which I love. I like black wheels with some machining done to accent parts of the wheel. Just depends on what you're looking for. Pro Comp and Eagle Alloy have some nice looking black wheels as well. Those two companies are less common, so it can be nice to have wheels that not everyone has.
Old Nov 23, 2014 | 02:44 AM
Blue150's Avatar
lol It's a Harry Potter truck, its a 2009 and 3/4's! Look forward to seeing it finished. Good work so far.
Old Dec 20, 2014 | 10:36 PM
iHarley's Avatar
Update? Looking forward to see the transformation.
Old Dec 21, 2014 | 10:28 AM
X2, this is a unique build. It's unfortunate to see you didn't get the '09/'14 bed though, but giving this "sandwiched" truck new life is great to see.
Old Dec 23, 2014 | 12:00 PM
fx4orum's Avatar
Wow - nice project! Looks great so far!
Old Feb 3, 2019 | 04:42 PM
gear86's Avatar
Headlights
UPDATEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!
Sorry its been awhile been pretty tied up!
Attachment 5876
how’s it going ? How did you bolt on the headlights?
Old Jun 18, 2021 | 11:27 AM
Ricardo Agustín's Avatar
Piezas necesarias
hood , fenders where a breeze to install. had to use new hood hinges, and new antenna mount which im still waiting on. should have the rest of the front done some time next week only missing the 2 bar fx4 front grille ot come in. everything else is laying around to get installed. whole front end has come out to $1200 with everything emblems, mounts etc, everything brand new.
Hola Desde Asunción Paraguay ....que buen trabajo !!!! Donde se consigue las piezas necesarias para este proyecto???
Old Apr 27, 2025 | 12:26 AM
jerseylowfive's Avatar
freedom off road sells a 4 in lift cheaper than a level kit and takes the rake out I had an 05 that I put 36s on a stock suspension. I forget the name is a tool. My buddy has it, but you basically screwed it into your lug nuts and I had this ball you just went back-and-forth and it massaged your real well plastic so they want it rub but I eventually went with that freedom kit and gave you the struts and the shocks and blocks for your rear
