continue the led thread...
Old Dec 31, 2010 | 10:31 AM
tj crowe's Avatar
Originally Posted by rednoved
Was the base different?
i take that back i got them to work haha but the 6k bulbs i ordered, the ones you recommended didnt match up but the blue led ones did so idk what to do. the dome bulbs look completely different so idk i'll just wait til 2011 to decide
Old Dec 31, 2010 | 10:34 AM
DarkShadowSTX's Avatar
Wait until tomorrow?
Post a pic of your domes. I had blue before I got red.
Old Dec 31, 2010 | 10:59 AM
rednoved's Avatar
Double check the packaging and order slip. A 194 style bulb should be the same base regardless of the color. Are you saying the color doesn't match or the base?
Old Dec 31, 2010 | 02:41 PM
tj crowe's Avatar
i ordered these which are the ones you have:
and these:
the blue ones worked in my plate lights, 3rd brake lights, and under hood light but not in my dome lights. the 6k white ones didnt work in anything
Old Jan 1, 2011 | 12:21 PM
rednoved's Avatar
That's really weird. Were they too long or what? Did they not turn on?
Old Jan 1, 2011 | 12:41 PM
MRLSU2U's Avatar
Keep in mind that led's are posi/neg sensitive, Have you tried switching up the connection? If you put it one way and it doesn't work, flip the bulb and try that.
Old Jan 2, 2011 | 11:51 PM
tj crowe's Avatar
my stock dome bulbs are double sided and they squeeze into clamps so neither led bulbs worked cause they are more of a plug in style with one side. as for the exterior bulbs the 6k bulbs fit but they would turn on
Old Jan 3, 2011 | 06:29 AM
You're still trying to find out about the domes or what exactly is the question? Domes are 578. Like this: http://www.v-leds.com/Interior-LED/D...-p8200027.html The new V-leds coupon is NYRES11 for 15% off until 1/15. Also posted here: https://www.f150online.com/forums/ap...de-thread.html
Old Jan 3, 2011 | 07:27 PM
how come the #194 bulbs didnt work for my plate lights?
Did you change them around? LEDs fit only one way, if they wont work pull them out and turn them 180, then reinstall.
Done is #921, plates are small #194s.
