New Stuff...
Old Nov 14, 2010 | 10:22 PM
  #31
the_cosworth's Avatar
what kind of lights are they? Also how do they look in the daytime?
Old Nov 15, 2010 | 08:01 AM
  #32
NCSU_05_FX4's Avatar
Originally Posted by sam1947
Guess what !!..They are illegal in every state in the union !!! HID lamps are for "OFF ROAD USE ONLY", unless it was factory installed, or in a properly retrofitted projector housing, but nobody is enforcing this.
Are retrofitted HIDs legal? I thought they had to come from the factory, ie OEM tested and approved, to be legal. There are plenty of things that we do to our trucks all the time that aren't exactly legal, look at tint, or cat deletes.
Originally Posted by BaseballBabe
... That is good to know because I don't want to get anything that is illegal for my future truck.
Being in CA that's probably a pretty good idea. I know you can get away with things over here, but I've heard they're a lot stricter out your way.
... get the optional 'capping' service..this also cuts down on glare from the front tip of the bulb ...
Would that still be necessary if using proper projectors? I see that as something you'd use if you're putting HID bulbs into a reflector housing, like the fogs. I had a pair of fog lights that had the tip painted with something or other to cut down on glare in the fogs when I was using the SilverStars (iirc).
- NCSU
Old Nov 15, 2010 | 09:14 AM
  #33
powerz69's Avatar
- NCSU
It's all illegal unless OEM or CSA tested DOT approved. Some say retrofits are worse because you're changing a CSA tested light, not just adding bulbs.
No you don't need capping done if using projectors. Capping will just cut the glare down as you won't see the tip of the bulb.
You already knew this, it's just early.
Old Nov 15, 2010 | 03:26 PM
  #34
mhockey9090's Avatar
I got an idea how about everyone just keep stock headlights and upgrade the bulbs to some halogens lol
Old Nov 15, 2010 | 04:08 PM
  #35
dirtyd88's Avatar
But I really doubt a law enforcement officer will stop you for actually spending the time and money to keep other drivers and yourself safe by going the correct route with HIDs....
plus, you technically aren't changing the factory reflectors, because you are no longer using them for light reflection
Old Nov 15, 2010 | 10:58 PM
  #36
powerz69's Avatar
I doubt it as well. I'm just saying they will not be CSA approved anymore. I'm not sure how state inspections are. Might just need a second pair of factory headlights if problems occur. No truck on the market has hid OEM headlights yet, so it's very easy to spot. :o
Old Nov 16, 2010 | 08:16 PM
  #37
Kr619's Avatar
The fogs are illegal to use on public roads (the HID bulbs) because of the glare issue.
I have HID bulbs on my fogs AND have been pulled over because of my lights but only cause I didn't adjusted my left headlight and blinded the crap outta an officer but I'm sure if adjusted correctly no one would mind
Old Nov 16, 2010 | 08:22 PM
  #38
dirtyd88's Avatar
yeah, which I find kind of hard to believe. I mean, they are noticeably better in certain aspects than halogens, but you would think as big as HIDs are becoming, both factory and not, that they would have put them in already....
what reason could they really have not to?
Old Nov 17, 2010 | 04:39 PM
  #39
fordtruckgirl's Avatar
Old Nov 17, 2010 | 04:57 PM
  #40
dirtyd88's Avatar
Old Nov 17, 2010 | 04:59 PM
  #41
Stu486's Avatar
1st pic is bad a
Old Nov 17, 2010 | 05:15 PM
  #42
Originally Posted by Stu486
1st pic is bad a
Thanks!
Old Nov 17, 2010 | 11:01 PM
  #43
Kr619's Avatar
nice piks
Old Nov 17, 2010 | 11:07 PM
  #44
DarkShadowSTX's Avatar
1st pic is bad a
X2. Looks great!
Old Nov 20, 2010 | 04:55 PM
  #45
hawaiian boy's Avatar
Originally Posted by fordtruckgirl
Awesome lookin' rig, girl!
