DIY Illuminated Door Sills
Old Jul 10, 2010 | 06:56 AM
  #31
DarkShadowSTX's Avatar
Looking good man. I can't wait to see it when its all done. Might have to do it to my truck but my sill is the diamond plate plastic and I would have to find a different way to do it since I don't have "Ford" to light up.
Old Jul 10, 2010 | 10:13 AM
  #32
KIETH 2000 XLT's Avatar
Doing a great job man! The only wire i know is the one that runs lights at the back of doors when opened, can maybe trace it back to kick plate!
Old Jul 10, 2010 | 12:39 PM
  #33
Drick's Avatar
Originally Posted by JackedUp99
Definitly doing this hope it works out. Where did you get the initial FORD plate from though?
Originally Posted by dannycruz837
the plates actually came with the truck. But i suggest printing out letters on a thick paper like a manilla folder, cuting them out and sharpie outline it to your dooor plate. I am going to do this on the 2 rear ones so the front 2 will say FORD and the back 2 will say F150.
Yep they got fancy door plates on the new ones JU
Old Jul 10, 2010 | 01:06 PM
  #34
NCSU_05_FX4's Avatar
http://www.amp-research.com/pdflibra...F150_04_07.pdf
Black / Yellow
Black / Pink
Black / Blue
Black / White
are the trigger wires for the doors for a SCrew.
- NCSU
Old Jul 10, 2010 | 07:28 PM
  #35
campo141's Avatar
Are we done yet?!?!?!
Old Jul 10, 2010 | 11:42 PM
  #36
dannycruz837's Avatar
So i tapped into the dome lights and i was like shiit yeah so i cut the extender wire and forgot to disconnect my battery..... my dome lights still work when i push them but neither the front or back turn on with the door:[ I hate this! i was too eager and forgot the most important step and now my dome lights are fckd. I will go now and try that diagram but any ideas on how to fix the damn lights to open with the door? I tapped into the harness at my fron dome lights and had my really long extender wire. I cut it and the dome lights shut off even though my door is open. Im going now to try those wires.... with the battery disconnected of course and see if it works. But i am going to the dealership tomorrow to see if they can fix that and my door handle on the inside, the spring broke and it opens but it doesnt go in haha but help would be wonderful
Old Jul 11, 2010 | 12:10 AM
  #37
I looked under both front and back door sill and cant find the wires you gave me:[ i have an 09 so its probably different:/
Old Jul 11, 2010 | 12:54 AM
  #38
coobies5's Avatar
use a test light to see what wires have power when the doors are open and voila!
Old Jul 11, 2010 | 01:04 AM
  #39
Any ideas to fixing the dome lights? I had my doors open and the lights were on. So i disconnected the front dome light harness and tapped into 2 wires and LEDs lit up. So i attached a wire and ran it to the door sill. i cut it to make it smaller and now my dome lights dont work. My instrument panel responds to my light dimmer but my dome lights dont turn on even if put in full on or off positions. im pretty much desperate to finsh this project to see how it looks so i may take it to my dealership tomorrow or maybe an autoshop idk but i want this done tomorrow
Old Jul 11, 2010 | 01:21 AM
  #40
well its 1212 and im going to bed. I may just check all the fuses. I read my fuse chart in mt manual and could find any fuses that could have a relationship with dome lights or dealing with lights coming on with doors:[
Old Jul 11, 2010 | 07:48 AM
  #41
thenewbreed's Avatar
Looks Great so far
Old Jul 11, 2010 | 10:52 AM
  #42
dome light is probably powered on by a computer
Old Jul 11, 2010 | 12:15 PM
  #43
Drick's Avatar
You better hope the dome light isnt powered on by a computer. If so did he fry his computer?! LOL damn
Old Jul 11, 2010 | 12:17 PM
  #44
Angry
dealerships are closed on undays along with automotive shops:/ im going to check all my fuses but if thats not the case, any idea where this computer could be and what it looks like?
Old Jul 11, 2010 | 12:19 PM
  #45
Yeah thats what im thinking now after reading that, i may have destroyed a computer would dome lights have there own compter?? cause everything works fine, my dimmer works, dome lights work if pushed
