My new lights
Old Apr 22, 2010 | 01:25 AM
MmmBuckles's Avatar
My new lights
I recently picked up a set of Hella 500FFs to put behind my grille. Well i fabbed up a bracket and got them all mounted and they look great. Only problem is it keeps blowing fuses and i have no idea why. i followed the install instructions as best i could. It came with a plug and play wiring kit with a relay. I have the relay plugged in and the red wire going to the battery, blue wire grounded to chasis, black wire goes to the lights, and the yellow goes to the switch. The fuse on the red wire that goes to the battery keeps blowing. When i first hooked them up they were working for a few minutes. I turned them off and back on again and thats when it blew. Did i wire something wrong? i have never had a problem like this before.
Old Apr 22, 2010 | 01:34 AM
Raptor05121's Avatar
double-check your wiring, something is shorting
also:
Old Apr 22, 2010 | 01:37 AM
dirtyd88's Avatar
Is the ground actually touching bare metal? Is it isn't gettig a good enough contact, it will keep tripping the fuse because it's not realizing the ground is there.
Old Apr 22, 2010 | 01:50 AM
MmmBuckles's Avatar
ya its touching bare metal. i guess ill try ground it somewhere else though. its annoying. ive gone through and entire thing of fuses trying to figure out the problem. ill get some pics tomorrow. wont be very great though since they dont light up yet lol
Old Apr 22, 2010 | 10:33 PM
MmmBuckles's Avatar
well i got the lights working. no more blowing fuses. I think i had the individual grounds for the lights too close together and they were making contact. i still need to get some HID bulbs to put in them, but these halogens will do for now
Old Apr 22, 2010 | 11:43 PM
b2therad's Avatar
Fail
Old Apr 22, 2010 | 11:59 PM
MmmBuckles's Avatar
Originally Posted by b2therad
Fail
??? care to elaborate?
Old Apr 23, 2010 | 12:42 AM
b2therad's Avatar
There are no pics. I was just jerking your chain though
Old Apr 23, 2010 | 01:02 AM
MmmBuckles's Avatar
haha. i know. i took some benadryl right before i started on the lights. i passed out as soon as i finished them and woke up at like 5. lol ill have pics tomorrow for sure.
Old Apr 23, 2010 | 01:37 AM
blackedoutV6's Avatar
im going to 2920 tomorrow, you gonna be in town?
Old Apr 23, 2010 | 01:41 AM
thejake1989's Avatar
wheres the pitchers
Old Apr 23, 2010 | 01:46 AM
Right here
Old Apr 23, 2010 | 01:51 AM
Originally Posted by blackedoutV6
Right here
fixed it
Old Apr 23, 2010 | 01:57 AM
good call!
Old Apr 23, 2010 | 01:59 AM
timmypstyle's Avatar
1-i dont see why the blue wire would be your ground....black is supposed to be the ground wire.
2-grouns too close together shouldnt matter as long as they are grounded. i have had 4 grounds from different things including a 760W amplifier on the same ground with no bad effects. a ground is a ground. biggest problem i had was finding a screw that was actually made from METAL!!!! i ended up drilling a hole in the floor and putting a screw in it and throwing the wires under it before i tightened it. then on another install i used the metal screws under the dash above the gas pedal. that was my 04 heritage i had. so far my 08 just has my halos to a toggle. toggle is grounded under the dash, halos are grounded under the hood.
