Frustration sets in
Old Jan 12, 2010 | 05:34 PM
  #31
f150fella08's Avatar
wow..i dont wanna buy HID's now!!!!!!
Old Jan 12, 2010 | 05:50 PM
  #32
migdaddy's Avatar
Honestly, dont let this thread discourage you. HIDS are awesome. I just am never pleased with anything i do, and i give up too easily. Everything was good when I had the stock heads, besides a little glare, but that didnt bug me very much. The lightning heads are badass looking, but they just need to be adjusted. When they are, my setup will be good. Also, realize that almost everything made today and is supposed to be "direct fit", ends up having to be fabricated. Nothing is perfect because it is made in Japan, China, and Taiwan, and not to factory spec.
Old Jan 12, 2010 | 05:57 PM
  #33
well..couldnt you take the little pins out of the back of your factory headlights? or is that now how you adjust these?
Old Jan 12, 2010 | 06:01 PM
  #34
migdaddy's Avatar
I thought about that, but i really dont want to break anything on them yet. Its just tedious work. Ill have them adjusted.
Old Jan 12, 2010 | 06:05 PM
  #35
i want to get the smoked lightning healights..if they need adjusting i may try the old pins..if not i will probably take them somewhere to get done..im not much for that kinda work..take them out..move them..put them back in..curse..take them back out..adjust some more..put back in...curse yet again...
you catch my drift
Old Jan 12, 2010 | 06:26 PM
  #36
blackedoutV6's Avatar
...its really not hard at all to adjust them.
especially if you have the ford tool to do it with
Old Jan 12, 2010 | 06:29 PM
  #37
where does one get said ford tool
Old Jan 12, 2010 | 07:04 PM
  #38
phattacorider's Avatar
Originally Posted by migdaddy
OK thanks for that. But how do I know when the light is horizontally correct? (the side output)
Measure the center of the beams to make sure the distance between them is the same as the distance bwteen the center of the bulbs on your headlight housings.
Old Jan 12, 2010 | 07:06 PM
  #39
Don't be deterred from getting HIDs. I'm going to invest in some again but for my stock headlamps. The only time you should worry about adjusting your lights is if you lift or level your truck (with drop shackles or lifting spacers) which increases the degree of your beam. If your truck is stock, throw in some xenon lights and you're ready to run.
Old Jan 12, 2010 | 07:50 PM
  #40
yea. mines stock..i dont really care about adjusting them unless i have to adjust the smoked headlights like i plan on getting
Old Jan 12, 2010 | 10:27 PM
  #41
Well if you're gonna smoke your headlights, it would be a good idea to get HIDs. I don't know about where you live, but it's not legal in Vegas because people make their really dark and the lights don't shine or reflect.
Old Jan 12, 2010 | 11:31 PM
  #42
http://www.amazon.com/Headlight-Adju...m_cr_pr_sims_t
seriously that tool makes your life so much easier
Old Jan 13, 2010 | 12:03 AM
  #43
migdaddy's Avatar
You have used it? How does it work??
Old Jan 13, 2010 | 12:11 AM
  #44
yeah, its awesome
normally you have to take your heads out, adjust them a little, and then put them back in and see if you adjusted them right.
that tool lets you leave the heads in, and it turns the adjusting screws from behind the header panel
Old Jan 13, 2010 | 12:19 AM
  #45
Carolinaboy32's Avatar
will that tool work on the 04+ ?
