DDm HID Question
Old Jan 9, 2010 | 02:57 AM
Ace_boy2099's Avatar
Hey sledman, Where did you run your wires and mount the Balasts? If you could could you get a pic of where the balasts are and tell me where you ran the wires?
I bought this kit for my truck but I am having a hell of a time trying to find somewhere to mount the balasts. I already have the Air filter in 3 pieces and the radiator resivoir loose so i can try and squeese my hands behind it on the drivers side, and I haven't even looked at the pass side yet aside from running the wires twice trying to find a good route so that the fit.
Old Jan 9, 2010 | 07:11 AM
sledman62's Avatar
I mounted my ballast under the plastic shroud that mounts over the hoodlatch/radiator area.The one with the belt routing sticker on it. I wanted to hide the ballasts etc, but it was about minus 15 Celsius that day, and during the re-installation of the plastic cover, I broke a chunk of it, and ended up throwing it on the pile of other stock parts I have taken off my rig.
Old Jan 9, 2010 | 11:16 PM
Originally Posted by sledman62
So I flipped around the bulbs first, but they still functioned backwards, so I reversed the red and white wires so they were connected red to lt grn/blk and white to lt grn/org and now they work properly. The hi beam pulls the bulb inward and low beam is fully out. Now I just need to align 'em tonight and I'll be done. Thanks guys for all the advice,you really helped me add to my rig.
Which wires is this? Is this the little 2 prong Hi/Low plug or the bigger (9006) balast plugs??
In my truck I don't have low beams at all, as soon as I turn them on it is on High beam while I have the high beam selector thing off and when i try to turn on the High beams nothing happens.
EDIT:
i just took the light bulbs out and put my halog's back in so I had functioning headlights for the weekend but I used a circuit tester and tested the signal's adapter plug that says when to turn what on and it is messed up. When the low beams are on it has power to both high and low beams, and when I turn on the high beams it just switches which is stronger but still both lights are on. I will be calling them monday to findout what they say till then I have the wireing in and done just disconnected from the battery and the bulbs out of the vehicle.
Last edited by Ace_boy2099; Jan 10, 2010 at 12:42 AM. Reason: additional information
Old Jan 11, 2010 | 03:16 PM
OK, I think my lights are fixed. I called DDM and talked to Ryan who was very helpful in assisting me to fix my wires. It turns out that the adapter plug was wired wrong (for my vehicle supposedly). Supposedly that is wired for "Most vehicle setups" so I had to take the adapter apart and re-position the pins to work correctly.
With the harness I have The white wire is the Lowbeams, Red wire is Highbeams, and the Blue wire is the Ground.
____|-|_____
.\--H-G-L--/
..\_______/
Above is suppose to be the 9007 Wire Connector from a 97-03 F150 (this is mine on my 99)
The plug should wire like the following (Looking at the back of the adapter)
____|-|_____
.\--R-B-W--/
..\_______/
Now I just have to test the Highbeams and make sure they go off when I turn them off later tonight when I get home from work.
EDIT 2:
Tested everything and it all works great now. Love the lights but think that next time (if there is one) I'll try the 6000K. lol
Last edited by Ace_boy2099; Apr 26, 2010 at 01:52 AM. Reason: trying to fix Text Pictures to look close to correct
Old Feb 21, 2015 | 05:11 PM
MGDfan's Avatar
Originally Posted by MRod941
I just got an hid kit I ordered through a audio shop for a F150 2001 and it's a Gen 4 kit so it has the harness and good stuff. So I was wondering if any body could walk me through the steps I know it only come with one headlight connecter . Once I have everything plugged I'm left with one connecter from one of the bulbs so I'm stuck there. I believe it's a bit xenon kit but the package it came in says race sport need help please a walk through the would help
Hey. Please do NOT post in another thread about the same questions that you already started a thread for: https://www.f150online.com/forums/ap...lment-hel.html
It's against Forum decorum.
MGD
Old Feb 21, 2015 | 09:56 PM
JackandJanet's Avatar
MRod, if you come back to this thread, I moved your post to the thread you started here: https://www.f150online.com/forums/ap...lment-hel.html on this topic.
Please don't make multiple posts on the same topic, and DO NOT hijack someone else's thread with a problem of your own. It causes great confusion and makes everyone unhappy.
- Jack
