chrome parking bulbs
Old Dec 16, 2009 | 04:00 PM
  #76
Yeah, it surely cleans up the appearance to them.
Old Feb 2, 2010 | 06:29 PM
  #77
f150ryder's Avatar
Question
I got my new plate bulbs finally in. These sure did the trick They are very nice and HID white with a hue of blue. Matches the reverse lights, and cargo lights perfect. And can be seen from quite a distance. They are shorter than the 194s I first ordered which means they will for sure fit better.
Heres the photos. They aren't as blue looking as they appear, they are 85% white 15% blue to my best judgment.
do u recommend buyin the 4-led license plate leds from superbrightleds with a 32 degree viewin angle
Old Feb 2, 2010 | 09:46 PM
  #78
Can you provide a link to it? I had two sets of superbrightled's 194 bulbs for the plate lights and each set one blew out, so I have no positive feedback for them.
Old Feb 2, 2010 | 09:58 PM
  #79
f150ryder's Avatar
u know what i jus went and bought the same ones u got from autolumination jus so i wouldnt hav any doubt.
thanks though
Old Feb 3, 2010 | 03:28 AM
  #80
cherokee2871's Avatar
Hey I am trying to order my dome light for my truck and I was wondering does the dome light have the post connection or the rigid loop connection to connect the light to the socket the application guide says 578 or 6411 and those are the differences in the two post or rigid loop connectors
Old Feb 3, 2010 | 09:16 AM
  #81
timmypstyle's Avatar
too bad they dont make black parking light bulbs. might look kinda cool with harley lights or mine. maybe when mine blow ill get the stealth ones. already bought some silverstar headlight bulbs. true white light
Old Feb 3, 2010 | 12:09 PM
  #82
Dinggus's Avatar
Anyone know what size bulb I'd need for my turn signals for a 2003? My orange tint is all flaky, and also, 194's fit the license plate correct? (I changed my to red, but, just making sure, I don't remember)
Old Feb 3, 2010 | 05:49 PM
  #83
The domes are rigid loop/festoon style. Only map lights are post connection bulbs. 578 is what the Ford trucks use.
The differences in rigid loop/Festoon and post is the festoon is the long bulb with connectors on the end ( domes ) and post is insert from bottom connection style.
Festoon
Post
You could try niteshading orange coated bulbs. The orange coating is near dark enough, a few shots of VHT niteshade would darken appearance some.
Signals are 3157. Go ahead and get the stealth/chrome 3157 bulbs if you have clear corners. Plates are 194s. No larger than 32mm.
Old Feb 3, 2010 | 08:05 PM
  #84
expedition4x4's Avatar
Darren I hope you don't mind me posting this
for those of you who don't want to spend that much for the led plate bulbs there's these 194/2825 LED Bulbs, they only cost $4.30 Shipped for 2 Bulbs they take almost a week to get to you but they are well worth it, i've had mine for almost one year and haven't had ANY problems here's some pics of them on my expy but somebody installed them on there f150 too
Old Feb 3, 2010 | 09:29 PM
  #85
f150fella08's Avatar
ok..ive been thinking about getting all LED lights for my truck, after seeing those pictures im definantly gonna! i have LED plate bulbs but i cheaped out and they arent bright at all..just look cool been pulled over 2x cuz they "couldnt read the license plate" i dont see how when they were tailgating the hell out of me!
anyways..i hear you need to put resistors or something with the brake/signal lights or they will blink fast??
Old Feb 3, 2010 | 11:01 PM
  #86
Not at all, its an open thread, Those are very bright for $4.30 LEDs! Definitely a WIN!
If you add LEDs for your taillamps and keep the front signal bulbs filaments yes you will need to do resisters. If you do a full LED take over in the parkers and tails all you would need is a LED capable signal relay so it transmits less watts to the bulb, and allows for proper signal speed.
Old Feb 3, 2010 | 11:45 PM
  #87
Thanks for the help Darren
Old Feb 4, 2010 | 03:18 AM
  #88
Dinggus's Avatar
Yeah, I have the lightning head's and corners are clear so you can see the orange flaky bulb.
Chrome Dome:
or
Titanium Chrome:
Old Feb 4, 2010 | 10:57 PM
  #89
yea i wanna put ALL LED's in ..LED capable signal relay?! please explain
Old Feb 6, 2010 | 08:09 PM
  #90
Better yet, i'll display
http://autolumination.com/equalizers.htm
Basically, its a new turn signal relay, replace your OEM for the LED capable one. End result, proper functioning signals.
