How do i remove emblems
Old Aug 3, 2009 | 11:08 PM
LonestarROB's Avatar
Originally Posted by LoneRanger93
If you have alot of residue left behind from taking the emblems off get yourself an eraser wheel, I used it to remove the tape left behind from a set of hood scoops and it took about 5 minutes after I spent 45 minutes trying to get it off by hand with goo gone and all that other crap. They just fit into any drill and are def worth the money, less than 10 bucks if I recall.
I'm guessing thats what I used to. Dunno what it was called, it was just what my bro said they had/use at their shop for getting that type stuff off. Kinda hard rubber like wheel. Worked soooo much better then anything else. Just keep it moving or it can burn into the paint job.
Old Aug 3, 2009 | 11:11 PM
Raptor05121's Avatar
Just use 70% isopryl rubbing alchohol to remove the sticky residue. Just be sure to use ammonia-based glass cleaner to clean the aftereffect so when you apply new badges the residue from the alcohol dosent un-sticky them
Old Oct 4, 2009 | 10:45 PM
bud1lite's Avatar
so my 06 f150 emblems have no bolts or anything?just tape?
Old Oct 5, 2009 | 09:31 AM
bikerfuzz's Avatar
I tried removing mine.Started and finished with tailgate.. There were three holes under the 150 logo bar. SO since IM no good with bondo..Put it back on, taped and painted.MUCH EASIER!!! AND CLEAN. Used patriot overlays all over. Ill post pics soon
Old May 23, 2010 | 02:25 AM
chiaronate's Avatar
See this is why I tried to find a current post, most I've found on this subject are from the late 90's. That rubbing wheel is right up my alley..I spent long enough just taking those emblems off, I don't need to spend a lot more time removing the left over glue. If I had known what a hassle it would be I would have just taped and painted, well live and learn. Where are the rubbing wheels available?
Old May 23, 2010 | 03:32 AM
MmmBuckles's Avatar
there are nuts on the back side you'd need to get access to. You'd have to remove the plastic fender liner, and the access panel on the tailgate to get access to the back of the emblems, then once the nuts are removed then you can work on getting the adhesive to break loose.
Long story short its much easier to carefully tape everything off you dont want to paint.
Or you can look at getting an emblem overlay from patriotdecals.com
Here's a silver one i had on my silver truck before it was totaled.
none of my emblems had nuts on the back of them. all of them are just stuck on. they do have alignment pegs though, but they arent holding them on at all
Old May 23, 2010 | 05:24 AM
the Ovals have two nuts on them
badges have alignment pins
Old May 23, 2010 | 06:19 AM
chiaronate's Avatar
Yeah I have two nuts also, can anyone tell me where to buy an eraser wheel? Local hardware store?
