LED OVERhaul.....and problems
Old Jan 31, 2009 | 06:28 AM
  #31
sherrod624's Avatar
turned my bulbs around, and nothing. its almost like when my lights are on they're the brights and dims are backwards. i put my old filament bulbs back in and they work correctly????? im almost to the point of giving up and just buying complete pnp led tails
Old Feb 3, 2009 | 09:11 AM
  #32
j2h1's Avatar
Can I ask where you got your bulbs ? I Have an all LED setup (nothing in the dash yet). I bought all my bulbs (except the brake, bought from http://www.ledtronics.com a long time ago) from autolumination including the flasher. I have not had any problems. I would almost say you have not so good bulbs since everything else sounds OK. I also have done the resistor on the brake and it works. My brake is not just a bulb but a Recon. I will say one thing, my mudflap leds do not work with the brake or flash when plugged in. I have the reverse dimming problem as you spoke of on all the lights including the big rig lights and four corners. I just cut the brake wire and use them as running lights only. I haven't figured that problem out. So in other words, see if you can try another kind of led bulb.
Old Feb 3, 2009 | 05:48 PM
  #33
sherrod624's Avatar
i got all my stuff from autolumination. the bulbs were the first ones on the 3157 list. 60 smt's. 30 bucks apiece i hope they aint the cheap ones
Old Feb 4, 2009 | 05:28 PM
  #34
j2h1's Avatar
I just got the same bulbs for my front turns! They have to be the most awesome bulb out right now! I don't think it could be the bulb now but I still don't know what could cause your prob.
Old Feb 6, 2009 | 09:03 PM
  #35
ScrewedUPF150's Avatar
I bought bulbs from them and had problems with two of them right out the box. Might need to return them. Bought new bulbs from an Ebay seller with 63 LEDs and no probs plus really bright. The same ones Stroville has. They are good.
Old Mar 17, 2009 | 07:17 PM
  #36
creimes's Avatar
Grote has a 5 pin LED flasher part # 44090 the #44890 is only a 3 pin, my 06 takes a 5 pin
