Running wire help
Old Sep 8, 2008 | 08:58 PM
FX4Screwdude's Avatar
Running wire help
Waiting for some lights to come in, my hope is to hook up some LED lights in the bed of my truck.
So thinking ahead here a bit, im looking for some advice in this mod area.
1. Gonna put a switch in the cab, not sure where yet.
2. what size wire should I use, from switch to lights, and switch to battery
3. wonder if I should put a connection block in somewhere and hook that up to the battery and then I could have other terminals available down the road for other things.
4. should I put the block in the cab or under the hood?
5. what size fuse do I need to use.
Thanks in advance
Old Sep 8, 2008 | 10:56 PM
mark razmandi's Avatar
some 16 guage should be good
Old Sep 9, 2008 | 04:51 PM
Raptor05121's Avatar
nah, too thick for LEDs. I'd run either 20 or 22 gauge and instead of doing all of that wiring, just run it up to your dome lights.
-OR-
you can mount your switch, but instead of running to the battery, just clip it in-line with your cig lighter fuse (3rd from top, left side, should be 20 amps) and will save you about 15-25 feet in wire.
Old Sep 9, 2008 | 08:12 PM
j2h1's Avatar
I agree with Raptor, tap into your dome wire. I did this for my "puddle LEDs". As far as wire, I ran I believe 20g for my power tailgate lock and cigar lighter plug in the bed.
