Switching projector functions?
Old Aug 20, 2008 | 11:16 AM
dirtyd88's Avatar
Question Switching projector functions?
So I have the 1-piece projectors that no one really likes. Since there is all this talk about how good the Depo projectors are, I was wondering is it possible to switch my low beam from the projector to the open lense?? I think it should be possible! I wasn't sure whether to post this in "Electrical Systems" or here, so I'm doing both.
Any thought and ideas would be appreciated!
Here is a pic of what I have to work with...
Old Aug 20, 2008 | 08:59 PM
NYfordguy's Avatar
Depends how wiring is supposed to be....my depos have the high beam in the projector! Odd.
Anyways mine are wired up as follows:
relays terminals:
30 power
85 ground
87 new lights (dual bulb, had a harness)
86 stock control wire
I had a harness remember, so that may change things. But it should be as easy as switching wires around. All you are doing is changing the pathway of current to turn on a different bulb.
Old Aug 21, 2008 | 05:52 PM
Raptor05121's Avatar
well the high beam bulb burns at a higher wattage. if you simply turn the wiring around, all thats going to happen is burn the highs when the lows are on, and burn the lo's when the hi's are on
Old Aug 22, 2008 | 04:14 PM
dirtyd88's Avatar
thats what i thought would happen...o well....maybe grab some Depo projectors next summer....right now installing a Clifford alarm....$$$$$
Old Aug 23, 2008 | 02:15 PM
blackf150lariat's Avatar
i think i see condensation
