fold in/out mirrors
I'm pretty sure he was implying that he already had the 'power fold' mirrors. Alas, as on my '08, they are manually activated. I think he wanted to know how he could wire them to actuate when he turned on and off his ignition. Coincidentally, just today, I discussed this very same thing with a friend.
Hutch
https://www.f150online.com/galleries...cfm?gnum=11782
Hutch
I think if he already had the fold mirrors this would be a large waste of time to wire. Seriously how hard is it to hit the fold button as you are pulling in to where you are parking. If he doesn't have Fold he has a lot of work in front of him. There have been alot of people trying to add the power fold mirrors. It can be done but there is alot of wiring that needs to be done. I think most people opt to wire in their only relays and toggle switches. I'm sure if you change where the power for the mirror is coming from you could get it to fold when you shut the truck off instead of hitting a button.
We carry all of the OEM components if you need them.
You could use a pulse timer to accomplish something like this. Find the circuit that controls the power mirror motors. You need something to activate the pulse timer, maybe the door lock circuit? Tap the door lock circuit to be the trigger for the pulse timer. The output of the pulse timer goes to the motor circuit. Lock your doors, the 12v pulse triggers the pulse timer to send 12v to the mirror motor for XX seconds whatever you set.
