Nightshades results?
Okay, I'm seriously looking into tinting my tails and 3rd brake lights. Problem is, I'd hate to tear into my brand new tail lights and the work be unsatisfactory. I understand all of the steps and procedures that go along with tinting the lights, but I'm just curious about the longevity of the tint and how well it will hold up to the elements.
Just to make sure of the steps or what I plan on doing, will this method turn out nice results?
sand until dull (800 grit)
clean and dry
hit with light coats of nightshades (until desired darkness)
wetsand when necessary
dry
clear coat (atleast 5 good coats?)
let cure (maybe a day or so?)
Will the clear coat give it a nice shine? If so, what can I do to give the lights a nice glossy finish?
clean and dry
dry
1)i didnt sand mine, the niteshade went on just fine
2)as for the clearcoats, on my last coat of niteshades i only waited 3 minutes for the niteshades to dry just enough to apply the clear. i wanted the niteshaes to still be tacky so the clear would stick no problem. a friend of mine that paints cars suggested this method. i tried it and came out good
3) i put 2 coats of niteshades 3 minutes apart
4)then 4 coats of clear 3 minutes apart
I sorry I don't understand what you mean by wetsanding??? Can you explain
Probably not the correct procedure to do it, but to it's just getting wet/dry sandpaper, and sanding a wet surface. So basically, keep spraying water (I've also heard of very slightly soapy water to help lubricity) on the lights while you sand them to keep the surface wet.
- NCSU
It's supposed to be give it a more lasting gloss and protect it. I've seen some Night Shade applications where the tail lights look opaque and dry. As for the protection, there have been people that say their Night Shade-only application chipped after a year or so.
